Go to Post The on-going debate on this thread is just because we care. - Steve Wherry [more]
Unread 12-03-2011, 20:55
de_ de_ is offline
AKA: Dave Edwards
FRC #1310 (Runnymede Robotics)
de_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the rough
How are <1.5 sec Minibots doing it ? Gearbox mods allowed ?
I still can't figure out how those super fast robots are doing it. The rules give you 3 alum. gears but none of them look big enough to have the 120t gear in use. There is some talk of bypassing 2 gears in the motor gearbox but that sure looks questionably legal.
Also, what are they using for traction material on the output shafts (like 118) ? (Electrical) Heat Shrink ? Surely there is no "hard" surgical tubing ?
Unread 12-03-2011, 20:59
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: How are <1.5 sec Minibots doing it ? Gearbox mods allowed ?
Removing/modifying the attached gearbox is perfectly legal. When removed, the motors spin far too fast to allow "normal" wheels. But with small diameter shafts used to climb the post, torque output is dramatically increased. Most of these smaller shafts seem covered in heat-shrink tubing, or surgical tubing.
Unread 12-03-2011, 21:16
DonRotolo's Avatar
Back to humble
FRC #0832
Try this: Remove the gearbox entirely. Drill a tetrix shaft with a #40 drill (0.098) in exactly the center and press it on to the motor shaft. Cover the tetrix shaft with latex tubing (hint: rubbing alcohol makes a fine lubricant to slide it on). Support the far end of the shaft (tetrix bronze bushing).
Two of these motor/shafts, a battery, 2 switches, and a clip or magnet to hold it on and up you go in (how many?) seconds.
Unread 12-03-2011, 21:30
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
If you don't have any rubbing alcohol on hand, warm water works just as well.
Where the experimentation and design comes in is where to put the motors:
I've seen ones with two motors on one shaft, two motors clamping onto the pole, and one with one motor on top and bottom.
I'm not going to tell you which was fastest
Unread 12-03-2011, 22:59
AndyH's Avatar
AndyH AndyH is offline
FRC #1098 (Rockwood Robotics)
AndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud of
That is more or less what we did. It is super light and very fast.
Unread 12-03-2011, 23:23
Chris is me's Avatar
AKA: Pinecone
Tetrix shafts are too small, go bigger.
Unread 12-03-2011, 23:35
Aren_Hill's Avatar
Build Nifty Things
whatever you say chris , depends on the surgical tubing size and the minibot weight
A guy who likes robots.
Unread 13-03-2011, 00:07
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
less is more when it comes to output diameter and force.
Unread 13-03-2011, 00:27
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Now this is where it confuses me, we purposely left our modified motors at our shop and used our unmodified minibot (got us really far) but apparently we had to sign a paper that stated we would not modify the gearbox. What was with that? I asked th inspectors, they said it was not allowed and said gracious professionalism should be kept. The inspectors never checked the minbots for modified gearboxes.
Unread 13-03-2011, 00:30
AKA: Pinecone
This is blatantly incorrect. You are allowed to modify the gearboxes but not the motors. Anyone who said otherwise just doesn't know the rules.
Unread 13-03-2011, 00:38
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Thank God. I don't know, our mentor, team captain and anyone with "authority" blantantly said "no David, no". Now for LA we are just making our MB super fast. Honestly though, we had a very very reliable deployment and minibot. (11:15 made to attempted ratio) It was slow, but that got us to Semi Finals and apparently we ended the competition at rank #4. I am impressed.
Unread 13-03-2011, 00:51
AKA: Pinecone
A slow minibot that makes it every match made our #6 spot on our pick list (maybe a little lower, I don't have it). It's all about consistency.
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Is very, very reliable 11:15? Less than half?
We haven't gone to an actual competition yet, but we've never failed in deploying - obviously, it will be different with all of the other robots flying everywhere, but still. What was yours like during testing?
Unread 13-03-2011, 01:03
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Honestly, it was fail proof, but not human proof. It is programmed that the robot backs up into the pole as it deploys so it is guarantee that it deploys. The 4 were human errors such as forgetting to put the deadman switch on or driving away from the pole as it deployed or going to the pole too late(we just get pushed around) But it makes it every single time as long as we set up around 25 sec. But we did not choose to use the arm (we zip tied it to the robot), so we went defensive (because of our design flaw, that was our down fall) then deploy every match.
Edit: that was not the gear ratio, I am saying reliability > speed. We had a 4 second minibot
Edit: that minibot alone got us to the #3 spot (we dropped down to #4 when we DQed for getting pushed into the scoring zone by the other robots several times at the semis)
Unread 13-03-2011, 01:06
The Lucas's Avatar
CaMOElot, it is a silly place
You can always modify any gearbox unless the rules (or Q&A) specifically states you cannot modify it because it is integral. Currently, the only legal modification you can make to the Denso window motor gearbox/motor is removing the pins (all other mods illegal, however you can do this). All other gear boxes are fair game for mods.
Robot Inspector
