Arcade mecanum drive
I have been looking around at info regarding mecanum driving. I have seen you really need to use tank drive. I also found it can be done with arcade too. Except that rotating doesn't work like in tank drive. I was thinking if we used arcade drive with the logitech attack 3d extreme joystick that has a swivel joystick, would rotation then work if linked up to the swivel axis. Could this work?
Thanks |
Re: Arcade mecanum drive
If you have a 3-axis joystick, it's simple. Use one axis (usually the Y axis) for forward/reverse, one axis (usually the X axis) for strafe right/left (sideways motion), and one axis (usually the twist axis) for rotation clockwise/counterclockwise. See attached screenshot of the Mecanum Cartesion VI in LabVIEW and the MecanumDrive_Cartesian in C++. Last edited by Ether : 12-03-2011 at 17:22. |
or, connect a gyro, input it to the mechanum vi for field oriented drive, make x strafe, y forward/back, and give your arm controller x axis rotation with y being arm up/down. so, the driver only controls movement, and forward will ALWAYS move the bot away from the driver station, etc. just an alternate method to consider.
The gyro doesn't solve all problems. You still want to be conscious of the direction your robot is facing when moving because the maximum speed of a mecanum strafing is less than the maximum speed moving forward/backward. So you'd still want to mostly travel forward/backward for getting places quickly.
#7
In directions other than pure forward/reverse or strafe, there is a theoretical reduction of maximum speed (even with friction-free roller bearings). This theoretical reduction reaches a maximum of 30% in the pure diagonal direction. *There may be some slow spinning of the rollers due to axial free play in the rollers, or under high loads (accelerating, climbing a hill, or pushing an object) when operating on a compliant surface such as soft carpet. |
#8
of a 3-axis joy |
#10
The point was that hooking up a gyro can make driving while turning easier. sorry if I was unclear, I was just saying how my team had set it up.
#11
Actually, I'm thinking about this, and maybe that would be relatively simple to try. If you just subtracted Y-axis 1 from Y-axis 2 and divided by 2, you'd have a rotation axis. You average Y-axis 1 and Y-axis 2 together to get your forward/backward axis. Then you average X-axis 1 and X-axis 2 together to get your strafing axis. Feed those three numbers into the mecanum code that all teams were given, and I think it would work as a tank drive. Quote:
Field-oriented control is easier to use in some ways but not strictly superior to robot-oriented control. For one thing, robot oriented control allows you to achieve the robot's maximum speed simply by hitting straight forward. Because you can't go as fast at an angle or sideways, that isn't always true on field oriented control. Also, moving the joystick straight forward always moves your manipulator straight forward (if it points forward), which can be preferable if you have the robot lined up to a field element and just need to move it closer. I talked to our driver for this year about the trade-offs, and he prefers robot oriented control. It does take some practice, particularly in a game like this year's where the robot is facing toward you so much of the time. Last edited by Nemo : 13-03-2011 at 20:22. |
#12
Regarding the tradeoffs between field-oriented vs robot-oriented...
It's really simple to set up the controls so that the driver can use whichever one works best for a given situation or maneuver. Set up one stick to operate robot-oriented and another field-oriented. Whichever one is non-zero takes control. Have a precedence rule in case both get grabbed, but in practice that won't happen if the same driver moves the same hand from one to the other. 2077 has used this arrangement with holonomic drive for the past two years. Our driver uses the field-oriented motion stick when looking directly at the field (3rd person viewpoint, 3rd person control) and the robot-oriented stick when looking through the camera (1st person orientation). We prefer rotation on a separate stick, common to both modes, but using twist on the motion sticks would work too. Try that with your 6wd and let us know how it goes . |
#13
While the IMO trite "lots of practice" is true in principle, and MAY even be the most important factor in driving effectiveness, it's not the only factor. Some control arrangements are better than others, and it's worth some effort to design one that works well for your situation. For a given amount of practice, whether a little or a lot, better control design gives better results, and better control design means better results with limited (imagine that) practice. As the only team in FIRST that doesn't have a full sized practice field and multiple practice robots on which dedicated drivers with no other tasks during the build season can practice on from day one, we've had to deal with the fact that our drivers can't get as much practice as we'd like them to have. We are no doubt unique as well in having on ocasion not had a working robot ready for driver practice until ship day or regional practice day. Practice is good, but good controls can help you deal with not getting as much of it as you'd like. One of the big practical advantages of holonomic drive is it gives you some control options you don't have with other arrangements |
