Go to Post Do what you do well and I'm sure there will be much hope in your future! - Collmandoman [more]
Unread 13-03-2011, 13:47
theNerd's Avatar
theNerd theNerd is offline
FRC #3329 (Cam Bots)
Rookie Year: 2110
theNerd is an unknown quantity at this point
Re: PID Loops
Originally Posted by Chris27 View Post
read this starting at page 23
D refers to a term that is proportional to he derivative of the error.
I refers to a term that is proportional to the integral of the error
I still don't understand to much about the details on how to find the derivative of the error (or the integral). I understand that the derivative of an equation is e.g.: instantaneous velocity, for instance F(x)' 4x^4 = 16x^3 (not pretending anything however I don't know the in depths of the derivatives all i know from second hand learning is the power rule). However my knowledge on integrals is null. How do you find the integral and derivative?
Unread 13-03-2011, 14:03
Re: PID Loops
If you are using PID functions that came with the language you are using, you don't have to. It is done within the provided library function.
All you need supply are:
the setpoint (the target value),
the process variable (the measured - with a sensor - value of what you are trying to control),
the 3 "gains" P, I, D
and any other optional inputs to the function such as output range
See attached screenshot of LabVIEW's PID
Name:	LabVIEW PID (help).png
Unread 13-03-2011, 14:20
Chris27's Avatar
Chris27 Chris27 is offline
AKA: Chris Freeman
FRC #1625 (Winnovation)
Chris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant future
Re: PID Loops
Computing the derivative is easy as it is just change over time. Computing the integral is a bit more involved. You can use Fourth order Runge-Kutta to estimate the integral
http://mathworld.wolfram.com/Runge-KuttaMethod.html
http://doswa.com/blog/2009/01/02/fou...l-integration/
If you are using a PID function of some library, you probably don't need to worry about computing derivatives and integrals and will probably just need to pass it the desired set point and the current location/sensor reading (like in Labview)
Unread 13-03-2011, 14:40
Re: PID Loops
"Euler's Method is the most common integration method for control systems . Control methods such as PID do not need exact integration to work well. This is because the purpose of the integral is usually to force the average error to zero to ensure that the controlled signal matches the command signal over long periods of time. Only rarely is there a need to control the integral of a signal. In those cases you may need a more accurate integration method."
Control System Design Guide
Second Edition
George Ellis
Page 82
Unread 13-03-2011, 15:39
archaopteryx archaopteryx is offline
FRC #2067
archaopteryx is an unknown quantity at this point
Re: PID Loops
I'm not a mathematician, but couldn't
Pedal = K * Error
, where K is a constant, simply do without K? If pedal and error have a direct correlation, why can't you just say that pedal = error and leave it at that?
Unread 13-03-2011, 15:44
Chris27's Avatar
AKA: Chris Freeman
Re: PID Loops
Originally Posted by archaopteryx View Post
I'm not a mathematician, but couldn't , where K is a constant, simply do without K? If pedal and error have a direct correlation, why can't you just say that pedal = error and leave it at that?
If you are trying to move your car at 50 mph and currently, the error from this target is +10 mph, does it make sense to push the pedal down at 10 mph? A correlation does not mean an equivalent 1 to 1 relation. Another example is if you are trying to drive your robot 5 feet forward and the current error is 4 inches. Does it make sense to tell the motors to drive at 4 inches? Built into the k value is unit conversion among other things.
Unread 13-03-2011, 15:54
Re: PID Loops
If you are trying to control position, then the error will be in inches (or feet or meters or whatever). In response to this error, you want to choose the appropriate command to your motors, which will be a voltage command... which roughly corresponds to a speed command. So the K is a scaling and gain factor to convert the error to an appropriate motor voltage (speed) command.
On the other hand, suppose you are trying to control motor speed. You want to go 2000 rpm and you are presently going 1900 rpm. So the error is 100 rpm. Would it make sense to give the motor a voltage command which is roughly equal to 100 rpm?
