Go to Post If you want to grow the program such that every student on the planet has the chance to participate, you have to start THINKING with a world-centric mindset. - Racer26 [more]
Unread 22-02-2011, 19:35
Aaron V Aaron V is offline
FRC #1325 (Inverse Paradox)
Aaron V is an unknown quantity at this point
Java Threads
So I have experience in programming - but one thing I haven't really looked into in detail are threads - I've always just let the compiler deal with them for me. I understand the concept of threads. The different parts of a programmer running essentially at the same time (alternating fast enough so that it doesn't really make a difference). I just don't understand what parts of a program constitutes as a difference thread. I've written a few additional classes for organisational purposes - do they have any effect?
Basically my main problem is that I need to pulse solenoids. It's simple to set it open or closed based on other input, but I don't know how to use time as an input. I figure I need threads because I don't want to stop everything else in the code.
Finally I've both seen the wait() function in the object class and the delay() function in the Timer class - I'm not sure which is better to use and which thread it effects.
Unread 22-02-2011, 19:38
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Java Threads
There is only one thread unless you explicitly make another thread. So to answer your question: most likely the same thread as the main thread. Unless the WPILib makes threads (I think the pid calculations do it)
Unread 22-02-2011, 20:46
wdell wdell is offline
AKA: William Dell
FRC #3999 (Shadetree Mechanics)
wdell has a spectacular aura aboutwdell has a spectacular aura about
Re: Java Threads
How often are you trying to pulse the solenoids?
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.Solenoid;
public class Pulser implements Runnable {
    Solenoid firstSolenoid = new Solenoid(1);
    public void run() {
        while (true) {
            try {
                firstSolenoid.set(true);
                Thread.sleep(1000); // sleep thread for 1 second
                firstSolenoid.set(false);
                Thread.sleep(1000); // sleep thread for another second
            } catch (InterruptedException ex) {
                ex.printStackTrace();
That will pulse the solenoid on for a second, then off for a second. The sleep() function causes the thread to wait (time in milliseconds).
wait() causes the thread to sleep until another thread issues a notify() or notifyAll() command. It doesn't set a specific time to wait for.
You might try replacing the sleep() function with Timer.delay(), I think that would get rid of the try..catch statements.
import edu.wpi.first.wpilibj.Timer;
    public void run() {
        while (true) {
            Timer.delay(1);
            Timer.delay(1);
To start the thread, you need to tell it to start() somewhere in your main program:
Pulser pulser = new Pulser();
new Thread(pulser).start();
Unread 22-02-2011, 20:47
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Robby Unruh will become famous soon enough
Re: Java Threads
Pulse solenoids, eh? Take a closer look at the Timer class, more notably getFPGATimestamp(). What I'd do is create a double to store a current timestamp using getFPGATimestamp(). Then in my code I'd make another more recent one that checks for a change in time. If the time has changed, I'd simply set the solenoid to false. Put that baby in a loop and bam!
Now if you'd prefer putting it in a thread than a loop, just make a Runnable interface and thread it.
Hope I helped.
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
Unread 22-02-2011, 21:22
Re: Java Threads
Alright, thanks everyone - I think I understand.
By default there is only one main thread. If I want to create a thread I can use the Thread class and can pass it a class inherited from "Runnable." Then no pauses in the run function will distract the main code.
To pause the thread I can either use the Timer class or the wait function, but the wait function requires a try...catch function.
Thanks for the quick responses.
Unread 13-03-2011, 04:46
dale5alfred dale5alfred is offline
AKA: Dale Alfred
Team Role: CAD
dale5alfred is an unknown quantity at this point
Send a message via Yahoo to dale5alfred
Re: Java Threads
What are three ways in which a thread can enter the waiting state?
Unread 13-03-2011, 15:00
Chris27's Avatar
Chris27 Chris27 is offline
AKA: Chris Freeman
FRC #1625 (Winnovation)
Chris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant future
Re: Java Threads
fyi, Runnable is an interface not a class.
Unread 13-03-2011, 17:06
Re: Java Threads
Sleep() makes the thread not runnable so it releases the processor so it doesn't waste resources polling the clock. The sleeping thread becomes runnable again when the sleep period has expired.
How is Timer.delay() implemented?
Unread 13-03-2011, 19:17
colinwarren colinwarren is offline
King of the Code Monkeys
AKA: Colin Warren
FRC #2456 (Recycle It!)
colinwarren is an unknown quantity at this point
Re: Java Threads
public static void delay(final double seconds) {
        try {
            Thread.sleep((long) (seconds * 1e3));
        } catch (final InterruptedException e) {
From WPILibJ's source. I would expect that the C++ threads are implemented on top of usleep(3).
Unread 13-03-2011, 22:26
purduephotog purduephotog is offline
Active Defense Design Engineer
AKA: Jason
FRC #3015
purduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the rough
Send a message via AIM to purduephotog
Re: Java Threads
We ran a neat little experiment (at least to me) to understand how the underlying threads were being executed.
Set the motor speed to one value- and then immediately set it to another value.
What we ended up with is a 'pulse' - sometimes it would hold continuous values... othertimes it would slow/speed up.
I had hoped it would help drive some points in with the programmers.
http://purduephotog.deviantart.com
Portrait Photography: "I used to say Immortalized in Silver, but now I say Captured and Squeezed by Electrons".
Unread 13-03-2011, 22:43
Re: Java Threads
How did this help you understand how threads are being executed? What points were you hoping to drive home?
Unread 14-03-2011, 11:54
AKA: Jason
FRC #3015
Re: Java Threads
Calls were being done asynchronously. That meant they were not executing in a linear fashion and you could not guarantee which would execute first.
If they executed linearly and in order, you'd have either no pulse (since the first set would be overridden when the code exited the loop) or a constant pulse rate since both calls were made in sequence, one after another, with no delays other than what the scheduler created.
Which mean the scheduler was pausing the robot.main classes and running things in the background- interrupt, so to speak, the main thread transparently. The students didn't (and still don't, I think) understand the implications of this. They think it just runs and runs and runs... they never see the pauses because they aren't presented to them.
One of the biggest issues I've had in trying to teach (and even some adults) is that just because you put two lines next to each other in the code- when dealing with hardware- you never know for certain (unless you're VERY careful) that they will execute properly. So it is always best to design with that thought in mind....
Unread 22-03-2011, 19:57
Re: Java Threads
If you start several threads at the same priority, what scheduling policy is used to run them concurrently?
Someone said it was not time-based, but rather based on number of bytecodes executed. Is this correct, and can anyone link to a document where this is discussed? I'm referring to the 2011 FRC Java Framework implementation here specifically.
