Thread Tools |
Rating:
Display Modes |
Re: Autonomy: How Did You Guys Do It?
Arm is only on timers... Hoping to add encoders soon. |
Now, I was going to use the rangefinder to find weather we are on the fork or the stop. I had the worry that due to the metal backing, it would give a wrong reading.
)you need to do a bit of filtering, but not a big deal. |
Our autonomous uses the encoders on the SuperShifter transmissions. The software uses the encoder values to actively make the robot drive dead straight. We also know reliably how far the robot has driven from the encoders. Encoders on the arm allow reliable positioning of the arm. The claw motors let us adjust the attitude of the tube when we reach the peg and then eject it onto the target peg. We have six different programs, one for each peg height. At GSR, we only ever ran the two for the top pegs, but have the others just in case. We can also select a delay before we start, which proved very useful in eliminations at GSR when we were on an alliance with 175 and 176 which scored 3 ubertubes in many of our elimination matches. See http://www.youtube.com/user/FRCteam1.../3/drbPrGJlroI for a match (semi-final 2) where all 3 of our alliance and 2 of our opponents scored in autonomous. Our robot is the middle blue robot which does not move until after the 4s delay we selected.
Noel |
Encoders on our drive train, encoders on our elevator, camera tracking, gyro angle correction, and sonar sensor. Consistently scores the ubertop on the top peg every time.
We decided that dead reckoning would be enough for this year given that the autonomous period is not very dynamic. Although our encoder code is done, we have had hardware problems and they are not on yet. Thankfully, our robot it pretty balanced and drives very straight. We didn't get an auto-mode in until yesterday in WI and it only scored once (in a somewhat humorous fashion), but will have one that should score pretty consistently week 4 in Midwest.
Given the hardware issues are fixed, the timing to approach will be changed to distance and a gyro would be added for turning around and getting ready. I don't think our robot functions act quickly enough to attempt a double-tube in 15 seconds. Last edited by BigJ : 13-03-2011 at 20:49. |
#7
We used the camera 100%. I have a feeling previous years vision targets have given the camera a bad name. The retro-reflective tape used this year is simply awesome to track and is the only target in my history that is not affected by the stage lighting used at the competitions. I hope that stuff is around for a long time to come.
#8
Yup. Our autonomous works in normal lighting, pitch black, or intense lights. We love that stuff.
#9
Wow! I've never done this before! I attempted to "track" still objects in various still pictures - a ball, a stick, a box - all color and at different lightings but I never was able to do this successfully. My main question is not how to apply an hsl threshold or clean up the photo after a threshold, but what to do with all that data I get using the stat VI's and such - I'm using labview. What does it all mean? and what on earth am i supposed to do with it to make my program know that it's looking at the target? thanks
#10
We used light sensors for line tracking, encoders for auto-correction, and an encoder on the arm for height determination. It's never failed. It's also kind of showy since instead of placing the tube it throws it down onto the peg.
#11
I used a gyro on the base to keep it straight, an encoder for distance, and a second gyro to determine arm angle. I'm hoping to rig up another encoder so as to have two straight-correcting sensors and average the two corrections, or use one as a safety net in case one malfunctions.
