Go to Post Do what you do well and I'm sure there will be much hope in your future! - Collmandoman [more]
View Poll Results: In your opinion, what claw design has been the most successful?
Roller Claw 76 75.25%
Grabber Claw 15 14.85%
Tube-inside Claw 3 2.97%
Entire tube manipulator 3 2.97%
Other 4 3.96%
Voters: 101. You may not vote on this poll
Unread 13-03-2011, 23:18
clayman's Avatar
clayman clayman is offline
AKA: Clayton
FRC #3175 (Knight Vision)
clayman is an unknown quantity at this point
Most successful claw design?
I was wondering what all of you think are the most successful claw designs so far, in general. Unfortunately due to some serious code issues that 3175 experienced, I wasn't able to watch many of the Waterford regional matches, and see what worked there. However, other regionals may have had more different designs. So, what do you think? What claw most easily got the tubes up?
Unread 13-03-2011, 23:21
Warlord Warlord is offline
He-Who-Does-A-Little-Of-Everything
Team Role: Driver
Warlord is a jewel in the roughWarlord is a jewel in the roughWarlord is a jewel in the rough
Re: Most successful claw design?
Those roller-claws seem to be the best and most popular so far.
Unread 13-03-2011, 23:29
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
In picking up tubes, it's fairly clear that roller claws are the most successful, especially when wide and near to the ground. For scoring, I can't say one specific type was especially impressive, though inside-tube manipulators and a few others (mainly those that hold tubes perpendicular to the ground) seemed generally successful.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 13-03-2011, 23:30
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
The rollers look like they have the potential to be the best when done right. However, I saw at least one team this weekend that made a bad one and it pretty much killed them. in that case a simple claw would have served them better.
2016 Central Illinois Winner. Curie Division finalist
Unread 13-03-2011, 23:33
Pinch claw WITH rollers.
Unread 14-03-2011, 00:14
Colin P's Avatar
Colin P Colin P is offline
MTU Robotic Systems Enterprise
AKA: Colin Putters
FRC #0857 (Da Yooper Troopers 3771, Unbolted Puppeteers 4363)
Colin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to behold
Bionic Barons have the best I've seen in person. It's a REALLY wide roller claw. The big spatula rollers seem to be the best overall. Claws that ride parallel to and an inch above the ground have the best gathering capability.
Snappers, as I like to call them, are fast at picking up tubes, but slow to score. A robot with a jointed arm and a pinching action claw is what i'd call a snapper.
Rollers are a bit slower at collecting tubes, but are unmatched in scoring speed. Working rollers against one another to articulate tubes is probably the best design for a robot with a jointed arm.
Elevator robots with inside tube collectors are the other best design, but the two are hard to compare.
Unread 14-03-2011, 00:17
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
I beg to differ: www.vimeo.com/20350475
Basel A's Avatar
AKA: @BaselThe2nd
What I liked about roller claw pickup was that teams could run into a tube, then immediately move backwards. No driver expertise needed.
What I liked about claw and inside tube scorers is that they don't affect the tube when they let go. Roller claws must spit a tube out, which can cause bounce and possible descoring. Grabbers can just let go.
That said, successful pickup and scoring is possible with any general design concept.
-Paul Copioli
Unread 14-03-2011, 00:24
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Roller claws appear to be the best by far at tube acquisition. What seperates the good roller claws from the great ones is how to spit the tubes out. With the smaller foot and no "stinger" it is much tougher this year to keep the tube on the rack than it was in '07.
Many of the best roller claws appear to attack this issue by using a pneumatics to open the jaws and release the tube instead of rolling it out.
Unread 14-03-2011, 00:47
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
There are a lot of good roller claws out there, but I submit our pincher for your consideration:
http://www.youtube.com/watch?v=0qEr4...eature=related
(Note: The sticky minibot deployment shouldn't be an issue going forward)
NC Gears (Newaygo County Geeks Engineering Awesome Robotic Solutions)
FRC 1918 (Competing at St. Joseph and West MI in 2017)
FTC 6043 & 7911
Unread 14-03-2011, 01:50
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
This
No, but seriously I think the rollers were the best. But the rollers with an extending arm was the best combo.
Unread 14-03-2011, 02:18
Basel A's Avatar
AKA: @BaselThe2nd
It appears 2337 is better than I, or the seeding system, gave us credit for...
-Paul Copioli
Unread 14-03-2011, 09:37
Brian Ha's Avatar
Brian Ha Brian Ha is offline
Teh Ha Kid
FRC #0302 (Team 302)
Team Role: Driver
Brian Ha has a spectacular aura aboutBrian Ha has a spectacular aura aboutBrian Ha has a spectacular aura about
I think the best one was a wide spatula claw. It didnt look like they had rollers. Basically that had a top spatula claw that was pneumatically fired and had a botton hand that had four fingers made of lexan that grabbed the tubes. If you dont know who this is its 2137. Their hand worked very well and effictively. So yeah thought it was cool.
Starcraft 2 Hit me up Cheese 972, or join the FRC chat room ingame
