Go to Post One of the cultural concepts that has emerged from the teams participating in FIRST is that ideas are worth sharing. - Alan Anderson [more]
Unread 18-02-2011, 15:51
Mr. Van Mr. Van is offline
#0599 (Robo-Dox)
Mr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond repute
A curious situation...
So we were testing our drive system last night and discovered a curious situation:
Of two motors in an AM SuperShifter, one is running opposite the other. Of course, this can often happen because one motor is wired backwards or its speed controller is receiving a reversed signal. In this situation, this is not the case.
The Jags that control both motors (tested individually) are both sending a positive voltage to the motors. The motors are wired identically. When each Jag is given the same control (via pwm), one drives the wheels forward and the other drives the wheels backwards.
We're at the point where we think that one of the motors is actually wired backwards internally.
Any ideas as to what's going on?
-Mr. Van
Coach, Robodox
Unread 18-02-2011, 16:05
Seathan93 Seathan93 is offline
AKA: Ian
FRC #1389 (The Body Electric)
Seathan93 is a name known to allSeathan93 is a name known to allSeathan93 is a name known to allSeathan93 is a name known to allSeathan93 is a name known to allSeathan93 is a name known to all
Re: A curious situation...
Have you tried reversing the motors in the code?
Sometimes the motors run in opposite directions (usually happens uniformly on one side e.g both right side motors). If that's the case your programmer can flip the motor in code to run in the opposite direction.
Unread 18-02-2011, 16:19
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
-Mr. Van
Coach, Robodox
Which motors are these? CIMs?
people have reported random polarity designations on the BaneBots 775, but I haven't heard of it happening on a CIM before.
Where did you get the motors from?
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 18-02-2011, 16:26
#0599 (Robo-Dox)
The motors are CIMs - all from previous KOP.
The problem occurs when the pwm cable is moved from one Jag to the other. When plugged into one Jag, the wheel runs forward, plugged into the other, the wheel runs backwards. (In each case, the other motor is back driven during the test.)
The code is the same...
-Mr. Van
Unread 18-02-2011, 19:00
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
even though this should be impossible to mess up since it fries the jags:
are the input voltages to the jag connected in the same way? (+ to +, - to -)
if power input to the jags is the same, I would test the same jag with different motors, this would confirm whether the problem is with the motor or the jag.
if the same jag induces different directions in different motors, the motors are to blame.
if the same motor turns different ways under different jags which have the same input voltage and signal, the jags are to blame.
let us know what happens, i'm curious!
-Leav
-Paraphrasing JFK
Unread 14-03-2011, 20:20
#0599 (Robo-Dox)
For anyone who is interested, it turned out that indeed one of the CIM motors is wired backwards internally. It runs in the opposite direction of all of the other CIMs we have.
Odd.
Has this happened to anyone else?
-Mr. Van
Coach, Robodox
Unread 14-03-2011, 20:33
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
We had a backwards CIM in 2010, ended up destroying a toughbox.
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 14-03-2011, 20:39
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Acidentally programmed my drive code wrong so one CIM was fighting the other. Thankfully nothing was damaged.
