Re: Will we see a perfect score?
I agree because 1114 was able to put up i think 3 logos, 2 ubertubes and a 1st place minibot in one match at pittsburgh.
18 Teleop tubes, 3 top row ubertubes, First and Second place minibots. A tall order? Yes. Possible? Yes.
If anywhere, we're going to see it in later regionals, or at the very latest Einstein. I predict we will see it, but it will most certainly be during elims, and probably from teams who appeared at more than one regional. |
If we see it, it'll be a very lucky teaming up of good teams in a qm, at MSC, STL, or IRI.
Actually, a perfect score is technically 194... You just have to be fortunate enough to have opponents that herd you their ubertubes across the centerline during autonomous so that each of your alliance's bots can score two ubertubes.
Now that will never happen.. FIRST Team 2530 "Inconceivable" |
haha! awesome point... a 6 tube autonomous with one tube on each peg. This would be truly awesome. for the sake of discussion though we'll keep it at a 6 tube autonomous so you are not dependent on the other alliance |
I expect an alliance at IRI elims might achieve this. Some alliance including three of: 1114,2056,217,148,254,968,233,111 and probably more I'm forgetting.
#7
<G11> ROBOTS may not break the plane of the CENTER LINE. Violation: PENALTY |
#8
technically they could push the tube so it straddled to the center line, and you could pick it up. The accuracy with nothing to reference would have to be incredible though.
#9
If there are any lineups with 3 awesome bots versus 3 broken bots, then this is feasible. My take is 2 main scorers with a carrier bot who gets the right tubes at the right times.
#11
I don't think so, Sunshine.
An Ubertube is not a robot. It is quite possible to push an Ubertube far enough over the line for another robot to grab it without going across yourself. It would take some relatively precision programming, but could be done. Now whether said Ubertube could be scored autonomously is quite another story. |
#12
