Go to Post The free exchange of ideas whether in Syn-Aud-Con or FIRST or Boy Scouts, has propelled me further in my field and in life, than anything else. - Al Skierkiewicz [more]
Unread 15-03-2011, 14:21
baroneje baroneje is offline
FRC #2848
baroneje is just really nicebaroneje is just really nicebaroneje is just really nicebaroneje is just really nicebaroneje is just really nice
Exclamation Minibot motors
Does anyone know how to attach an 3in. long axle directly to the tetrix motor, no gearbox at all?
Unread 15-03-2011, 14:29
Re: Minibot motors
Is it legal to remove the gearbox from the P/N 739023 Tetrix motor, and use the motor (without the gearbox) on the MINIBOT ?
Unread 15-03-2011, 14:31
Colin P's Avatar
Colin P Colin P is offline
MTU Robotic Systems Enterprise
AKA: Colin Putters
FRC #0857 (Da Yooper Troopers 3771, Unbolted Puppeteers 4363)
Colin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to behold
Re: Minibot motors
Yes, that's pretty much the only way to get up in less than 3 seconds.
I saw a team put shaft collars onto the remaining gear and then tinker around with that, but it kills the gear.
PVC and (lots of) PVC cement?
Unread 15-03-2011, 14:32
FRC #2848
Re: Minibot motors
It doesn't say you can't. I saw team 16, 148, and 118 at the Alamo regional with these modified motors and the officials didn't say anything.
Unread 15-03-2011, 14:38
Re: Minibot motors
Ether,
It is legal to remove the gearbox and use the Tetrix motor alone.
From the Q&A...
Tetrix Motor/Gearbox
Posted by 2011FRC2775 at 01/13/2011 05:10:19 pm
In regards to to R47 and R93 Is the Gearbox on the Tetrix motor considered to be integral to the motor? Can the gearbox be removed and/or modified as long as the motor itself is not changed.
Posted by GDC at 01/16/2011 11:47:05 am
No, the gearbox is not considered integral to the motor. Yes, the gearbox may be removed and modified.
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Re: Minibot motors
Modify Gearbox: http://forums.usfirst.org/showthread.php?t=16779
Remove Gearbx: http://forums.usfirst.org/showthread.php?t=16187
Unread 15-03-2011, 14:39
Re: Minibot motors
Off the shelf collars would not be legal. We made them by machining a bolt.
Unread 15-03-2011, 14:47
Re: Minibot motors
Does anybody have a link to the motor curves of the motor without the gearbox?
Unread 15-03-2011, 16:45
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Minibot motors
http://www.chiefdelphi.com/forums/sh...8&postcount=15
Unread 15-03-2011, 18:15
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Minibot motors
Back to the original request now:
Yes, we do. I suppose you want us to tell you?
Here is an example, you can experiment from here:
Take a Tetrix metal shaft. Carefully drill a hole with a #40 drill bit into the very center of one end. Press this onto the motor shaft carefully, to avoid damage to the motor (meaning: Hammering is bad).
Some tips:
Hot metal expands, which may make an interference fit easier to assemble.
Long shafts under radial load must be supported at the far end.
Latex tubing is not very abrasion-resistant.
Rubbing alcohol makes a fine lubricant for assembling rubber onto metal.
Good luck.
Unread 15-03-2011, 19:20
Re: Minibot motors
Originally Posted by sanddrag View Post
Thanks. I just found this, which has speed and current in addition to power and efficiency.
The gear ratio is 52:1, so the motor free speed is something >8000 rpm.
Unread 15-03-2011, 19:24
Chris is me's Avatar
AKA: Pinecone
Re: Minibot motors
Do keep in mind the motor gearbox is almost laughably inefficient (hovering around 50%)
Unread 15-03-2011, 19:32
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Re: Minibot motors
R92, S. Indicates "mechanical fasteners" are allowed. A shaft coupler/collar mechanically fastens two shafts together...there were several examples of minibots that passed inspection with such couplers/collars this weekend.
Unread 15-03-2011, 19:34
WileyB-J's Avatar
WileyB-J WileyB-J is offline
4976 Georgetown Rebels
FRC #4976 (Rebels)
WileyB-J will become famous soon enoughWileyB-J will become famous soon enough
Re: Minibot motors
Pretty sure they changed that to "mechanical hardware" in an early update, might wanna check the current version manual.
Unread 15-03-2011, 19:51
Re: Minibot motors
Nope, they changed it from "mechanical hardware" because all sorts of people were getting confused. It reads "mechanical fasteners".
