Go to Post The GDC has spoken, we have listened and will follow their ruling. - ChuckDickerson [more]
Unread 15-03-2011, 17:16
Re: pic: In_CIM_erator
Just discovered this thread. From the vantage point of a month later, I suppose it is possible that Hawiian Cadder was using a defective RS775. Do you still have that motor? Do you have another RS775 you could compare it to with your "thumb test"?
A few additional remarks. Peak output power occurs at half free speed, not at stall (post #42), and not at the intersection of the torque and speed curves (unless the graph is scaled to make it so) (post #17). Kv (rpm/sec) is the velocity constant, not the motor constant. Motor constant is Km which is (stall torque)/sqrt(input watts at stall) (post #27).
Unread 16-03-2011, 01:16
Creator Mat Creator Mat is offline
FRC #2338 (Gear it Forward)
Creator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the rough
Another thing just take a look at the motors. I know this is a tad unscientific but doesn't a bigger motor generally = more power? Plus ask yourself if a manufacturer made a smaller lighter motor that was more powerful than a bigger heavier motor why would they make the bigger motor in the first place? So why is it not so off base to conclude that the RS 775 18v is more powerful than the RS 550 motor? Especially when the manufacturer's specs back up this idea.
2010 Midwest Spirit award
2010 Midwest Quarterfinalists
2010 Wisconsin Quarterfinalists
2009 Midwest Finalists
2009 Wisconsin Quarterfinalists
2008 Midwest Rookie AllStars
Unread 16-03-2011, 01:20
Bigger motors only have more power if they aren't case shorted half the time or more.
Guess which motor has a tendency to have a case short?
Unread 16-03-2011, 02:58
Chris is me's Avatar
AKA: Pinecone
How does that add to the discussion about the 775's peak power?
The 550s have other reliability issues, just more obvious and less damning (i.e. trying to stall them will quickly result in smoke, while the 775s can take more abuse. when the case isn't shorted.)
Unread 02-04-2011, 11:00
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Just to resurrect the discussion about whether the 18 V RS-775 motor from BaneBots (M7-RS775-18) is a Mabuchi product, see here and here for what a Mabuchi sold by a reseller looks like. You can clearly see the differences in case style from the Mabuchi spec sheet, and if you look closely at the first link, you can also pick up the (painted-on) Mabuchi "M" logo on the side of the case, with what appears to be a part number underneath the reseller's label.
So I stand by my contention that the Banebots RS-775 from 2011 is not a Mabuchi motor.
