Go to Post I would say FIRST is quite an addiction.............but one of the BEST addictions you'll ever have. - RoboMadi [more]
Unread 15-03-2011, 19:51
Re: Minibot motors
Originally Posted by Chris is me View Post
Do keep in mind the motor gearbox is almost laughably inefficient (hovering around 50%)
Yeah, I just discovered that as I was comparing the test data with and without the gearbox. I was wondering if it's even the same motor.
Unread 15-03-2011, 19:52
Re: Minibot motors
Joe,
The correct read on R92 is
S. Mechanical fasteners (e.g. screws, bolts, etc),
I would be hard pressed to include COTS shaft couplers in that definition without direct GDC guidance on the subject. Something manufactured from the allowed materials would be OK.
Unread 15-03-2011, 19:53
boomergeek's Avatar
boomergeek boomergeek is offline
AKA: Mr. D (Dick DiPasquale)
FRC #0241 (Pinkerton Robotics)
boomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant future
Re: Minibot motors
baronep1,
Do you have a lathe with a drill attachment and someone that knows how to use it?
Do you have a drill press?
We would have had difficulty with drilling a proper hole or press fitting the aluminum round bar without both machines and some expertise...
If no local expertise, find a local team or machine shop that will lend you a hand to make the parts and assemble them to your specifications.
There are many teams that try to get by with hacksaws, vises and power drills and don't know what a gear-puller or a press fit is.
To me, it's not very sporting to get you to try to imagine what the right machine shop tool is if you have not been trained in a motor machine shop nor have access to one.
Now it might be that you have a motor expert mentor and machine shop and you asked here before asking the local team mentors: but I find that unlikely.
Good luck.
(I would not advise you to try to make the hole in the cylinder or try to attach it to the motor without the proper tools).
Unread 15-03-2011, 20:02
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Re: Minibot motors
Joe,
Right, Update 3 changed hardware to fasteners...But "etc" is so esoteric, Al! I do agree that someone considering purchase of shaft coupler should check with the GDC though.
Unread 15-03-2011, 20:07
boomergeek's Avatar
Re: Minibot motors
Inefficient?- it all depends on perspective...
@$30 a pop and a tendency to quickly burn out when bumping into a stop- the motor with gearbox is very efficient at generating revenue.
The first reason we got rid of the gearboxes is the motor sounded so much better (i.e., not that sound of impending doom) when relieved of their gearboxes. We've had 5 motors: 2 with gearboxes have already burnt out.
Unread 15-03-2011, 20:13
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
Re: Minibot motors
We tried this but the motors would smoke.
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 15-03-2011, 20:15
Tom Line's Avatar
Tom Line Tom Line is online now
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Minibot motors
The motors will smoke because your axle is far far too large: you are not gearing correctly for the torque of the motors. It also looks like you're trying to run square shaft through a round bushing, which isn't good at all friction wise.
Round shafts through those bushings with a much smaller OD.
Unread 15-03-2011, 20:28
joeweber's Avatar
Coach team 1322
Re: Minibot motors
It's not a square shaft, It is the shaft that comes with the tetrix kit with a flat spot. If I lathe down the shaft smaller I would still run into the problem of contact with the pole and the friction required to go up it with out slipping. I place rubber electrical tap over this shaft which is legal but there is nothing else small enough that is legal.
Unread 15-03-2011, 20:40
boomergeek's Avatar
Re: Minibot motors
We found that precision on centering is critical and we had the accuracy of a lathe.
If the shafts are contacting more than about an inch from to the motor, there is significant wobble.
If the load is more than 1.4 lbs per motor, there isn't typically enough of the shaft in contact with the pole to prevent destruction of the tire.
Having the right amount of normal force on the tires is critical. The optimum is a function of the robot weight.
Unread 15-03-2011, 21:16
Re: Minibot motors
Joeweber,
I would agree that a direct drive like that is under the torque needed to climb and so the current is high. You reminded me/us that Tetrix does include shaft collars. Is that what is pictured? I have seen a number of teams using gears scavenged from the Tetrix transmission to reduce the speed and increase torque while mating with the motor pinion perfectly.
Unread 15-03-2011, 21:43
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
Re: Minibot motors
There are a couple of easy ways to modify the gearbox. One way results in a ratio of 31.2:1. The other way results in a 10.4:1 gearbox. We ran the 10.4:1 gearbox with roughly a 2" diameter wheel in KC. The minibot climb time is about 2 seconds. This seems a bit slow, but with a reliable deploy it does okay.
Unread 15-03-2011, 22:24
Re: Minibot motors
For what it's worth, a compilation:
2011-01-28 Tetrix motor+gearbox; spec from Tetrix website:
http://tetrixrobotics.org/Building_S....aspx?moid=721
2011-01-21 Tetrix motor without gearbox; test data from R Wallace:
http://www.chiefdelphi.com/forums/sh...8&postcount=15
2008-05-12 Tetrix motor+gearbox; test data
http://www.chiefdelphi.com/forums/at...0&d=1274226112
Unread 15-03-2011, 22:33
Re: Minibot motors
Tom, you said the 10.4:1 mod was easy. Would you be willing to post a bit more detail how you did this? Thank you!
Unread 16-03-2011, 00:41
Captaindan's Avatar
Captaindan Captaindan is offline
AKA: Daniel
FRC #0364 (Team Fusion)
Team Role: Driver
Captaindan is a jewel in the roughCaptaindan is a jewel in the roughCaptaindan is a jewel in the roughCaptaindan is a jewel in the rough
Re: Minibot motors
if you have extra motors laying around and money to buy more obviously they are going to burn go ahead and take the gearbox off
but a 3sec robot is possible with proper engineering it is totally up to the builder/team
Unread 16-03-2011, 01:44
Tom Line's Avatar
Re: Minibot motors
Ether, you'll find upon opening the gearbox that the gear that meshes with the motor can be placed on a different shaft. Indeed, it can be put on one of the outside shafts and be the only intermediate gear between the motor and the output shaft gear, if one machines the total height of the gearbox itself down enough. Machining the gearbox down is necessary for the motor to reach the helical gear while the helical gear drives the output shaft. Take one apart and you'll see what I mean - play around with moving the gears around onto different shafts.
This reduces the gearbox inefficiency a great deal, and allows you to use a small wheel directly driven from the gearbox output shaft, increasing efficiency even more.
