| Thread Tools |
Rating:
Display Modes |
Team Update #18
Re: Team Update #18
Can you imagine how this will effect the Finals on Einstein? You know there are going to be minibots that are almost equal speed...
no!!! thanks FIRST that you make it clear i like updates and seeing this from what you learned in previous week but cant this wait till championship
Re: Team Update #18
Not a fan. Witnessed MANY minibot climbs this weekend at San Diego that most certainly imparted 3-4 N of force yet were not auto triggered. It's going to suck when the field fails to work correctly and teams lose points they should have earned.
Re: Team Update #18
I saw far too many missed triggers (at least they appeared to be) on webcast this past weekend to be comfortable with this update going into our event this week.
Re: Team Update #18
I agree, Cory. More than once a 1 second minibot with significant momentum failed to trigger. Is it possible that the triggers still need too much contact time to register? BTW, we had a great time partnering with you guys and 3704!
#7
Re: Team Update #18
When that happened at the WI regional, the refs manually triggered it.
#8
Re: Team Update #18
We've since increased the speed a lot, more along the lines of 254, and the impact is pretty violent. |
#9
Re: Team Update #18
The triggers are designed with multiple sensors, and the FMS only looks for 1 of those to be triggered for any amount of time. Thus making the minimal amount of force still trip the tower. The towers have been tested and proved to be much more accurate since week 1, so I think this should be a non-issue now at week 3.
#10
Re: Team Update #18
Whatever the circuitry I am 100% confident that there were multiple (greater than 10) instances at San Diego where minibots compressed the platform upwards into the sensors without the tower actually triggering. |
#11
Re: Team Update #18
Re: Team Update #18
Re: Team Update #18
The sensitivity of the towers now is highly dependent on how the field crew that implemented the fix did it. Really, what the minibots are doing now are pushing the bottom plate up about a quarter of an inch. However, that distance may vary depending on how meticulously the field crew assembled the plates. I was told to get up on the ladder on Saturday morning and adjust the distance a little bit more and make sure that the distances were equal, but it was only by an eighth of an inch by so. FIRST's solution works, as long as the instructions are followed to the T. Last edited by Karibou : 15-03-2011 at 21:16. |
#14
Re: Team Update #18
It seems pretty clear there are still problems with the field and I don't just say this because the tower failed to trigger with our minibot. It was a very common occurrence. |
#15
Re: Team Update #18
Assuming a .5 kg minibot can climb 10 feet (about 3 m) in 2 seconds, and that the plate depresses at most 2 cm (0.02 m), this means that its average (not top) speed is about 1.5 m/s and:
Using the work-energy theorem, W = KE F*d = .5(m)v^2 F = .5 (m)(v^2)/d F = [.5 (.5 kg) (1.5 m/s)^2]/.02 m F = 28 N ...is (actually less than) the average force needed to stop said minibot (because 1.5 m/s is the average speed, and not the top speed). If the compression distance is less, the average force will be higher. If the minibot is faster than 2 s, then the average force will be higher. If the minibot is more massive than 0.5 kg, then the average force will be higher... ...which means that, if the towers are doing their jobs properly, no one with what I would consider a "competitive" minibot has anything to worry about -- and if they DO NOT trigger the towers, then we have direct evidence that the specifications given (2-4 N of force to trigger) are simply wrong. I'm quite tired, and didn't put much thought into this. Anyone want to poke holes in my analysis? Last edited by pfreivald : 15-03-2011 at 21:22. |
