Re: Deployment Brainstorm
smart, i was thinking about doing something similar, might try that if its working well for yall. Does that plate also provide side support? That isnt exactly possible with our minibot design unfortunately.
We used this kind of an idea...
http://www.chiefdelphi.com/media/photos/36149 http://www.chiefdelphi.com/forums/sh...threadid=89991 By putting two tubes on the minibot, and then two pins on the robot, we never had any problems with it falling off or coming loose. we used about 4 inch pins and the shorter tubes to save weight. It does great with side to side movement and keeps the minibot in a perfect vertical orientation. |
yea, we thought about this problem as well. Luckily the deployment system was attached to extrusion so it could be lowered and we shorted the pins a little. Currently the minibot is not in contact with the pins when it crosses the 18" mark.
We are using a retainment system we learned from Simbotics last weekend, a ball detented spring pin tied to a robot structure, the pin is pulled as the minibot is deployed via a string tied to something on the robot which allows the pin to be pulled straight out during deployment... Simple!
With the tube and pin design I mentioned before the minibot lifts itself off the pins when it contacts the tower and begins to climb. That way if the deployment system comes out to early, you don't lose the minbot! |
#7
1114 uses a 1/4 inch ball spring pin which holds the minibot on a small nylon block, if the holes are right the only way to get the pin out is to pull it, it wont come out on its own due to the spring loaded ball at the end. Simple and effective! |
#8
Huh, our team came up with a solution that has both of the ideas in this thread
Our deployer is a drawer slide, which is run by a fisherprice motor and goes straight out the back. The MINIBOT is held on by 4 inch aluminium tubes on the HOSTBOT end, and some PVC on the MINIBOT end. Our MINIBOT's motors start running when it gets a little way off the chassis, with a pin tied to the HOSTBOT and a limit switch on the MINIBOT. I can see why the GDC likes capitalizing stuff now . |
#10
Ours sounds very similar. Two 1.5 inch vertical pins on HOSTBOT deployment platform, PVC tubes on MINIBOT. One of the pin/tube setups had a horizontal locking pin though a hole in both the tube and pin which was attached to the HOSTBOT via strong cord so that the pin pulled out 'just in time' At setup, excess string was bunched up and secured with a loose zip tie so that it didn't mess with the HOSTBOT or otherwise get tangled.
Worked extremely well. |
