Go to Post I am a FRC Coach/Mentor I don't know the meaning of the words "days off" or "rest". At least not from January to May. - Bob Steele [more]
Unread 15-03-2011, 22:32
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to behold
Send a message via AIM to RMS11
Deployment Brainstorm
So we got our third iteration of our deployment system set up and are pleased with its performance, but realized one major issue when testing today: our minibot just isnt stable enough to hold for a two minute match. I am trying to come up with as simple and lightweight solution as possible, but know I must be missing something. What are other teams doing?
So far I have considered servo holding down the minibot, a long piston through the minibot, a frame that mounts concentric to the shaft of rotation like a casing, a casing just fixed in place when the minibot sits rotated into the bot, an electromagnet (still need to check on legality, hadnt gotten that far yet), trying to get the pin to go all the way through into the minibot slideout the goes vertical through the minibot also (doubt how effective this would be).
Currently, the system is set up with 3 vertical posts through holes in the minibot with an extra support to hold the battery, but in a 2 minute match we doubt this will last. Here is a video of the whole system: http://www.youtube.com/watch?v=WE0EN...eature=related
What are other teams doing? All these ideas we have had so far either seem over complicated or impractical. At alamo, 118 had an awesome 3D printed bracket, unfortunately we dont have this capability. Any brainstorming help would be great! Thanks!
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
Unread 15-03-2011, 22:42
clayman's Avatar
clayman clayman is offline
AKA: Clayton
FRC #3175 (Knight Vision)
clayman is an unknown quantity at this point
Re: Deployment Brainstorm
Our minibot has a small piece of tetrix shaft sticking out each side, which fit into 3"ish deep notches in pieces raised up from our deployer. We have had no issues of it falling out.
Unread 15-03-2011, 22:45
RMS11's Avatar
Safety!!!!
AKA: Rick
Team Role: Driver
smart, i was thinking about doing something similar, might try that if its working well for yall. Does that plate also provide side support? That isnt exactly possible with our minibot design unfortunately.
Unread 15-03-2011, 22:49
J_Beth J_Beth is offline
AKA: Justin Beth
FRC #0935 (RaileRobotics)
J_Beth will become famous soon enoughJ_Beth will become famous soon enough
We used this kind of an idea...
http://www.chiefdelphi.com/media/photos/36149
http://www.chiefdelphi.com/forums/sh...threadid=89991
By putting two tubes on the minibot, and then two pins on the robot, we never had any problems with it falling off or coming loose. we used about 4 inch pins and the shorter tubes to save weight.
It does great with side to side movement and keeps the minibot in a perfect vertical orientation.
"I Wanna Be A Robot Maker!!!!"
Unread 15-03-2011, 22:56
Dan 1038's Avatar
Dan 1038 Dan 1038 is offline
Team Leader
AKA: Dan Stauft
FRC #4740 (Spartan Robotics)
Dan 1038 has a reputation beyond reputeDan 1038 has a reputation beyond reputeDan 1038 has a reputation beyond reputeDan 1038 has a reputation beyond reputeDan 1038 has a reputation beyond reputeDan 1038 has a reputation beyond reputeDan 1038 has a reputation beyond reputeDan 1038 has a reputation beyond reputeDan 1038 has a reputation beyond reputeDan 1038 has a reputation beyond reputeDan 1038 has a reputation beyond repute
We are using a retainment system we learned from Simbotics last weekend, a ball detented spring pin tied to a robot structure, the pin is pulled as the minibot is deployed via a string tied to something on the robot which allows the pin to be pulled straight out during deployment... Simple!
Dan
2011-Present
Founder & Team Lead, FRC Team 4740 - Spartabots, Nashville, TN
Founder, FRC Team 3945 - Cobrotics, Whites Creek, TN
Mentor, FRC Team 4306 - Robo Komodos, Franklin, TN
2005-2011
Mentor, FRC Team 1038 - Thunderhawks, Liberty Township, OH
Unread 15-03-2011, 23:59
AKA: Justin Beth
Cool, my only issue with that is what happens if the pin comes out on its own?
With the tube and pin design I mentioned before the minibot lifts itself off the pins when it contacts the tower and begins to climb. That way if the deployment system comes out to early, you don't lose the minbot!
Unread 16-03-2011, 00:13
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We have a setup like this. I'm concerned about the pins still contacting the minibot when it crosses the 18" line (we have a rather tall minibot). I guess we'll see on Thursday. We never thought to check when building it.
Unread 16-03-2011, 00:15
AKA: Justin Beth
yea, we thought about this problem as well. Luckily the deployment system was attached to extrusion so it could be lowered and we shorted the pins a little. Currently the minibot is not in contact with the pins when it crosses the 18" mark.
Unread 16-03-2011, 00:35
RMS11's Avatar
Safety!!!!
AKA: Rick
Team Role: Driver
Thanks, yet another elegant solution by 1114!
Unread 16-03-2011, 01:08
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Huh, our team came up with a solution that has both of the ideas in this thread
Our deployer is a drawer slide, which is run by a fisherprice motor and goes straight out the back. The MINIBOT is held on by 4 inch aluminium tubes on the HOSTBOT end, and some PVC on the MINIBOT end. Our MINIBOT's motors start running when it gets a little way off the chassis, with a pin tied to the HOSTBOT and a limit switch on the MINIBOT.
I can see why the GDC likes capitalizing stuff now .
Unread 16-03-2011, 10:47
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Ours sounds very similar. Two 1.5 inch vertical pins on HOSTBOT deployment platform, PVC tubes on MINIBOT. One of the pin/tube setups had a horizontal locking pin though a hole in both the tube and pin which was attached to the HOSTBOT via strong cord so that the pin pulled out 'just in time' At setup, excess string was bunched up and secured with a loose zip tie so that it didn't mess with the HOSTBOT or otherwise get tangled.
Worked extremely well.
Unread 16-03-2011, 12:04
Dan 1038's Avatar
Team Leader
AKA: Dan Stauft
Beth,
1114 uses a 1/4 inch ball spring pin which holds the minibot on a small nylon block, if the holes are right the only way to get the pin out is to pull it, it wont come out on its own due to the spring loaded ball at the end. Simple and effective!
Dan
2011-Present
2005-2011
