Go to Post The true beauty is, no matter what the game (Yes, even 2001), we spend these 6 weeks going crazy with design strategy, and trying to figure out a way to work the plot twists that the GDC throws at us...and its a blast. - Andy Grady [more]
  #31   Spotlight this post!
Unread 11-02-2011, 00:17
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Re: pic: In_CIM_erator
if the rs550 had more torque at a higher speed doesn't that mean it has more power?
  #32   Spotlight this post!
Unread 11-02-2011, 00:38
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Yes but none of the specs support this and your thumb test did not appear to measure speed.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
  #33   Spotlight this post!
Unread 11-02-2011, 01:14
AKA: Isaak
Team Role: CAD
thumb test = slowly apply load until motor stalls, rs550 gave me a burn because it didn't stall. rs775, stalled very easily. this is in contradiction to the spec sheets, and based on discrepancy between spec sheets i think teams should actually run the motors to see how much power they actual give off, we don't have a dyno, but someone who does can measure power.
  #34   Spotlight this post!
Unread 11-02-2011, 01:21
AdamHeard's Avatar
Lead Mentor
This is not proof whatsoever.
I see no reason to not trust the banebots specs.
  #35   Spotlight this post!
Unread 11-02-2011, 01:23
AKA: Isaak
Team Role: CAD
ok, but i recommend you turn one on at the least, compare it to the RS-550.
  #36   Spotlight this post!
Unread 11-02-2011, 01:27
Hawiian Cadder- It is amusing that you are continuously questioning the intelligence of Adam as well as team 33, among others. while they try to explain to you your errors.
I am pretty sure Adam has turned on one of the motors 5 weeks into build...
  #37   Spotlight this post!
Unread 11-02-2011, 01:35
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Also, on the "thumb test" the 775 shaft is significantly larger than the 550 shaft. You're able to get a much better grip on it, and apply more torque to it.
Not at all scientific nor conclusive.
  #38   Spotlight this post!
Unread 11-02-2011, 01:45
AKA: Isaak
Team Role: CAD
i made a hub out of delrin which press fit onto the rs 775 axle, on the other side it pressed onto the rs550 axle, they were both the same delrin drum which was tested.
  #39   Spotlight this post!
Unread 11-02-2011, 01:46
AdamHeard's Avatar
Lead Mentor
I got a test for ya, a good ol drag race.
Lock the shafts of the two motors together, and run them opposite directions. Whichever doesn't die is the winner!
  #40   Spotlight this post!
Unread 11-02-2011, 01:58
AKA: Isaak
Team Role: CAD
i was planning on making my delrin hub into a pulley tomorrow and see which motor will lift a little weight the fastest, we are not using either of the kit motors either so i may try a drag race, that will likely fry one or both of the motors though.
  #41   Spotlight this post!
Unread 11-02-2011, 02:02
Andy A. Andy A. is offline
Getting old
FRC #0095
95 used the banebots published spec sheet to design a shoulder joint. It is operating as intended, which I would not expect to be the case if the actual motor performance and the specified performance differed by such a wide margin. Given the frictional loses we're undoubtly encountering it's a little surprising that it's performing as well as it is, truth be told. We were conservative and planned on using two of these motors ganged together, but are finding out it operates just fine on one. We'll likely use the second anyways but I wouldn't be surprised to find out the motor is operating a bit above the projected rating.
In fact, not only is it operating spot on at the design speed, it is holding level a pretty substantial arm for ~10 seconds (stalled at about 15 amps maybe) with no apparent heat issues. I'm petrified of holding any longer then that right now, but I suspect it could do it. That places it well above the FP motor in my book on the size/weight/power/reliability value matrix.
Whatever the actual performance is it's way closer to the banebots published spec then it is to 70 watts.
  #42   Spotlight this post!
Unread 11-02-2011, 02:07
Imaginary Friend
AKA: Kevin Li
Team Role: Student
You should do a series of weights until you reach stall that way you can find peak power. You should also use a power supply to control the voltage if possible.
Kevin Li
596 - Sciclones
  #43   Spotlight this post!
Unread 14-02-2011, 00:30
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
We engineered a component on our robot using the R775. We knew the weight, and using the calculated power of the R775 we figured it would take: 0.8 seconds to traverse the distance we needed. It performed exactly as it was engineered to, and the R775 provided the exact amount of power that it was supposed to.
I have absolutely no reason to doubt the manufacturer's specifications on these motors. They appear to be correct.
  #44   Spotlight this post!
Unread 15-03-2011, 17:16
Just discovered this thread. From the vantage point of a month later, I suppose it is possible that Hawiian Cadder was using a defective RS775. Do you still have that motor? Do you have another RS775 you could compare it to with your "thumb test"?
A few additional remarks. Peak output power occurs at half free speed, not at stall (post #42), and not at the intersection of the torque and speed curves (unless the graph is scaled to make it so) (post #17). Kv (rpm/sec) is the velocity constant, not the motor constant. Motor constant is Km which is (stall torque)/sqrt(input watts at stall) (post #27).
  #45   Spotlight this post!
Unread 16-03-2011, 01:16
Creator Mat Creator Mat is offline
FRC #2338 (Gear it Forward)
Creator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the rough
Another thing just take a look at the motors. I know this is a tad unscientific but doesn't a bigger motor generally = more power? Plus ask yourself if a manufacturer made a smaller lighter motor that was more powerful than a bigger heavier motor why would they make the bigger motor in the first place? So why is it not so off base to conclude that the RS 775 18v is more powerful than the RS 550 motor? Especially when the manufacturer's specs back up this idea.
2010 Midwest Spirit award
2010 Midwest Quarterfinalists
2010 Wisconsin Quarterfinalists
2009 Midwest Finalists
2009 Wisconsin Quarterfinalists
2008 Midwest Rookie AllStars
