Go to Post 2010 game piece--- participation medals - johnr [more]
Unread 16-03-2011, 08:18
team63 team63 is offline
FRC #0063
team63 is an unknown quantity at this point
Tetrix Bearing Size
Does any one know the OD and ID of the Tetrix Pivot Bearings?
Unread 16-03-2011, 08:59
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Re: Tetrix Bearing Size
If you are talking about the bronze bushings I believe they are 3/16 id and 5/16 od.
Bruce
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 16-03-2011, 09:37
rees2001 rees2001 is offline
AKA: Rees
FRC #0340 (Greater Rochester Robotics)
rees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond repute
The OD is .315", the id is .115".
good luck
Unread 16-03-2011, 09:54
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
good luck
Assuming you are talking about the servo bearing.
id is 3mm
OD is 8mm
It is about 3mm wide. It comes with a screw, nut and a couple of washers.
Unread 16-03-2011, 20:45
AKA: Rees
id is 3mm
OD is 8mm
Yep, the servo bearing. I just checked it quick with a set of calipers. I tried a 3mm screw but it didn't fit in the one I checked.
