Go to Post Just proves those guys have loco-motives - Wayne C. [more]
Unread 15-03-2011, 14:26
brettreardon123's Avatar
brettreardon123 brettreardon123 is offline
FRC #1212
brettreardon123 is infamous around these partsbrettreardon123 is infamous around these partsbrettreardon123 is infamous around these partsbrettreardon123 is infamous around these partsbrettreardon123 is infamous around these partsbrettreardon123 is infamous around these parts
How to Setup Solenoid using Pneumatics Bumper
We have been having trouble getting the solenoids to actuate when using the pneumatics bumper as opposed to just using a relay with a spike. We are not sure if we are even wiring it correctly, does anyone have a diagram or a tutorial on how to do this? Please reply ASAP, our regional is in two days.
Thanks,
Brett
Brett
Unread 16-03-2011, 16:09
smcmahon's Avatar
smcmahon smcmahon is offline
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
smcmahon is an unknown quantity at this point
Thumbs up Re: How to Setup Solenoid using Pneumatics Bumper
I'm far from a pneumatics expert here Brett, but I can tell you how our team did it this season..
We had the two air outputs coming out of the solenoid (Festo) and then down to the two air inputs on our two-way air cylinder.
The solenoid (Festo) also has two sets of black/red wires. Small gauge, probably 22AWG or so. We attached little 2-pin header on those, much like you'd find on the female end of a PWM cable.
We attached those pins to the pneumatic bumper, in Slot 8 of the cRIO. We used pin sets 8 and 6.
In the code, we set up two buttons as Boolean variables. When the button is pressed the code receives TRUE. When the button is released and not being touched, it reads FALSE. This also sends a signal to the pins noted above, thus energizing the solenoid in the particular direction.
So, in our case, when we press one joystick button, it energizes pin set 8, and then solenoid forces the air piston to extend. When we press the opposing button, it energizes pin set 6, which causes the solenoid to retract the piston.
I'm sure much better info could be got from someone with more experience. This is very basic telling of our setup.
A note: we had been using 12-volt solenoids. If you are as well, be sure that you have the pneumatic bumper wired to a 12-volt power source (on the PD) and not 24-volts. I have no idea what sorta bad stuff could happen if the voltages don't match up.
FRC 2656 | FTC 5526 | VEX 9656
Unread 16-03-2011, 16:57
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
Check the Team 358 site. They have very good tutorials on all things punematics.
-Alex
2010 Washington DC Regional: Engineering Excellence Award
