Go to Post This is going to be leet. Or something like that. I can't wait. - Billfred [more]
Unread 04-03-2011, 19:08
Arjun Namineni Arjun Namineni is offline
FRC #4384
Arjun Namineni is an unknown quantity at this point
Cypress I/O Module
My team has decided to use the Cypress Board this year, and we are not entirely sure how to program it. Can anyone either explain it or reply with a link to where I can find further information?
I have already gone through the "How to Configure Your I/O Module" pdf on the KOP website, but it doesn't really explain how to program it.
Thanks in advance!
2009-2013: FRC 226 - Student
2014-Present: FRC 4384 - Mentor
Unread 04-03-2011, 19:28
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: Cypress I/O Module
Thanks in advance!
You don't program it. You load firmware onto it (as explained in the pdf you found), and then connect wires to it appropriately.
In your robot code, you access the inputs/outputs that you hooked up via the DriverStation class, or if you use the more advanced features of the board, through the DriverStationEnhancedIO class.
Unread 04-03-2011, 20:42
FRC #4384
Let's say, for example, that I have buttons hooked up to the Cypress Board and I wanted to grab the state of each button. How would I do that inside my C++ code (i.e. what class and function etc. would I use)? Also, I am not worried about the dashboard.
Unread 04-03-2011, 22:42
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
DriverStationEnhancedIO &dseio = DriverStation::GetInstance()->GetEnhancedIO();
// read first analog input
float value = dseio.GetAnalogIn(1);
Brian K
Team 1225 Robotics Mentor
Unread 16-03-2011, 17:52
kws4000's Avatar
kws4000 kws4000 is offline
Team Mentor - Programming
AKA: Krazy Karl
FRC #2405 (Divided by Zero)
kws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the rough
We have just installed all Cypress software from disk, and we are only able to get it to be recognizzed on an XP machine and not on the classmate, wich is Windows 7. The softwatre claims that a service has not been statrted.
What to do?
Unread 16-03-2011, 18:45
You can try starting the CyMiniProg3 service.
It's under Control Panel->Administrative Tools->Services
Unread 16-03-2011, 18:52
kws4000's Avatar
AKA: Krazy Karl
Not there. Itr appears that it does not install correctly into Windows 7.
Unread 17-03-2011, 23:36
kws4000's Avatar
AKA: Krazy Karl
Exclamation Re: Cypress I/O Module
It does not install correctly on 7.
However, some folks over at team 266 at WMR COmpetition told me to unistall Cypress and redo updates. I have done all of them and still no coms (little light on I/O tab lit). File version is v2 as included in public files on classmate, as configured from another laptop.
Wellll???????????
Unread 18-03-2011, 02:42
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
Although I don't know how to help you with your current problem, I will let you know that the IO Board can be flaky. Last year we would have to restart our classmate before our matches and pray that the IO would be there. This year we are still using the board, and although we have not had any problems yet, we have programed all of the necessary functions to work with joystick buttons and not the IO Board if and only if the main driver is holding one of the triggers, that way, even if IO goes down, we can still play our match. (although the drivers' hands will be kinda cramped)
But I'd say work first on getting it to work and I'm really sorry that I don't have any answers for you, other than I can tell you it works with the Windows 7 on our Classmate.
www.sharkattack744.com
Unread 19-03-2011, 00:05
kws4000's Avatar
AKA: Krazy Karl
Red face Re: Cypress I/O Module
I would like to put out a big thanks to all of Team 226 at the West Michigan meet. It took a full install of evrything: refornmating of DS, all updates, and 2 hours, but she works now! The Cypress board even gets recognized when the DS is already running!
Note to evryone: DO NOT INSTALL CYPRESS DISK ON LAPTOPS THAT YOU WANT TO DRIVE WITH!
It's done: HALLE-.... oh hang on, it's lent.
Now I just have to start assigning variables and finishing wiring.....
