Go to Post Roses are red/Violets are blue/I'll write a poem/Once build season's over. - Taylor [more]
Unread 16-03-2011, 20:57
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
I Have A Question About Pointers
Now this is where I have not been able to wrap my head around: do pointers take up space in the memory heap? I know that pointers just reference to a specific memory "slot", but is it a "physical" object in the memory that takes up space? Or is it just what the compiler sees and uses to get the data that the pointer references to? Also does this mean an array is also like a pointer, just references to multiple objects? I am not sure if I am asking the questions right.
I have been using C++ for years and I have not thought about this until recently. I just assumed pointers were just an object that references to an objects location; are they like "#define"s where only the compiler uses value?
#include <iostream>
#include <stdio.h>
#include <stdlib.h>
using namespace std;
| r |    Register(s)     |
| a |   %eax, %ax, %al   |
| b |   %ebx, %bx, %bl   |
| c |   %ecx, %cx, %cl   |
| d |   %edx, %dx, %dl   |
| S |   %esi, %si        |
| D |   %edi, %di        |
uint16_t assemblyAddition(uint16_t input1, uint16_t input2);
int main()
    uint16_t *input1;//This should not take up any space in memory right?
    input1 = (uint16_t*)calloc(2, sizeof(uint16_t));//This allocates a piece of memory for 2 shorts (16 bits * 2 == 32 bits) and initializes it.
    //Now the pointer points to that memory region
    if(input1 == NULL)
        cout << "YOU DUN GOOFD!";
        return 1;
    input1[0] = 0x0;//This sets the referenced object (that was allocated above) to 0
    input1[1] = 0x0;
    cout << "Number 1: ";
    cin >> input1[0];
    cout << endl << "Number 2: ";
    cin >> input1[1];
    cout << endl <<"Result : " << assemblyAddition(input1[0], input1[1]) << endl;
    free(input1);//This allows the allocated memory to be used again, but does it set everything to 0?
    return 0;
    uint16_t result = 0x0;
    asm("addw %%bx, %%ax;" : "=a"(result) : "a" (input1), "b" (input2));
    return result;
edit: since pointers have a datatype, does it take up as much space as the datatype (for my example, 32 bits? 16 * 2 == 32)
I thought they just stored the memory slot number, so I am just confusing myself.
Unread 16-03-2011, 21:04
Re: I Have A Question About Pointers
A pointer takes up space in its own right, usually 32 or 64 bits depending on the memory map. It isn't just a compiler construct - it gets used at run time. This lets you do pointer arithmetic.
Unread 16-03-2011, 21:08
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
So my example uses 64 bits of memory from just the variables? 32 from the pointer it self, 16 from short, and another 16 from the other short. I don't know how much the streams use up.
Unread 16-03-2011, 21:09
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
If it is a variable, it takes up space in memory. A char variable takes 1 byte, a short variable takes 2 bytes, a long variable takes 4 bytes, an int on a 32-bit machine takes 4 bytes. A pointer variable on a 32-bit machine also takes 4 bytes.
int A = 40;
long B = 50;
int *ptrToA = &A;
long *ptrToB = &B;
addr           value      variable name
1000    |       40       |  A
1004    |       50       |  B
1008    |      1000      |  ptrToA
1012    |      1004      |  ptrToB
Unread 16-03-2011, 21:20
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
So the cRio has 32 General Purpose Registers and 32 Floating Point registers? Since cRio apparently has a PPC core.
On the other hand, I am impressed that the mars rovers used VxWorks as their OS.
Does the cRio have a 64 bit structure?
So if a pointer does take up that much space, it seems like a structure would be more efficient for variables under 32 bits than using singletons.
Unread 16-03-2011, 22:12
Predicting how much memory is used for a given bit of code requires quite a bit of knowledge about the machine architecture. One of the most common tradeoffs in electronics and computer is "space for speed". This is true in your code, but often true in the computer architecture itself.
As an example of this, how much space is taken by
struct { int8 a; int16 b; }[1000]?
The naive answer is (1+2)*1000, but on many architectures, alignment rules force the int16 to be on a two byte alignment and for the struct to actually take four bytes. Additionally, when you malloc you'll find both internal and external fragmentation. You will often find memory managers making all sorts of tricks to avoid locks, to speed up contention for the free list, etc.
Additionally, while a pointer represents space, if they are in a local scope they may actually be just a register and use no memory. This is also true of ints, floats, and any local of sufficiently small scope.
For future reference, if you use sizeof(int*) or any other type, that is a good estimate for memory usage, but all of the factors listed above and many more make an impact.
Greg McKaskle
Unread 17-03-2011, 08:04
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
In your example input1 DOES take up space in memory (whether or not you call the calloc), 4 bytes on the stack of the vxWorks task in which it executes. After the calloc call, input1 contains an address that points to a location in the heap. The space used in the heap is probably 4 bytes but could be more. For example vxWorks has an option to insert boundaries around heap allocations (where it inserts a certain pattern) to assist in memory analysis. Greg's observations about alignment also play a role.
The data type referred to by the pointer does NOT changed the amount of memory the pointer itself consumes. But it does determine how pointer arithmetic increments/decrements. For your example, input1++ increases the address pointed to by 4 bytes. If input1 were declared to pointer to a double, it would increase by 8 bytes and so on.
I think our version of the PowerPC is a 32-bit machine thus integers and pointers are 4-bytes.
HTH
Unread 04-04-2011, 04:59
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Oh man, I have been reading this assembly book. EVERYTHING makes so much more sense to me now.
Unread 05-04-2011, 18:50
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Is it safe to assume that it runs in protected mode? Sorry for the double post, but I can't edit my latest post. Now is anyone else thinking of writing the code for next year in assembly? Obviously not the whole thing, but some of the calculations and stuff like that would not be too bad. Well, if you are already doing pointer arithmetics, it can be replaced with assembly code.
Unread 05-04-2011, 18:53
mikets's Avatar
Software Engineer
Are you talking about the PowerPC processor in the cRIO or are you talking about Intel processor? Your initial post listed all the Intel processor registers. So I am not sure which one you are asking?
Unread 05-04-2011, 19:00
demosthenes2k8's Avatar
demosthenes2k8 demosthenes2k8 is offline
Graduated but not gone
AKA: Matt Soucy
FRC #0166 (Chop Shop 166)
demosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to behold
Send a message via AIM to demosthenes2k8 Send a message via Yahoo to demosthenes2k8
I'm sorry, but you appear to have a need to overcomplicate everything. If there's really no need to write the code in assembly, it would probably be better to write it in C++, because the compiler can probably write better assembly than a human.
GSR Dean's List Finalist 2011
Unread 05-04-2011, 19:24
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
That is true, that was written for my computer, the thread started out as a general question and is becoming more specific. I know the PPC syntax is different. I don't think that its much of a big deal to transition from AT&T syntax to PPC syntax. I know in the IA 32 systems, it runs in protected mode. But I am not sure about PPCs
There is no need, but I have the mentality that I would learn so much more from it. I mean there is no NEED for me to even be on the team. You see where I am going with this?
Unread 05-04-2011, 19:44
mikets's Avatar
Software Engineer
In Intel processor architecture, there is the concept of real mode versus protected mode. But there is no such thing in PPC. In PPC, you probably mean kernel mode versus user mode. But that's entirely different thing. For historic reason, Intel processor boots up into real mode where it uses real mode address space seg : offset to form a 20-bit physical address. That will allow you to access only the low 1 Mbyte of memory. PC BIOS runs in this environment and loads the OS loader into memory (Actually much more complicated than that, but this is the simplified view). The OS loader will then set things up and switch the CPU to go into protected mode. The setup includes setting up the virtual memory address tables GDT, LDT and the interrupt table IDT. So once the OS is booted, the CPU is already in protected mode. Everything including both the OS kernel and applications are run in protected mode. However, in protected mode, there are different privileges. Again, for historic reason, Intel processor supports 4 different privileges (rings). But most of the operating systems support only 2 privileges and they are usuually called kernel mode or superviser mode and user mode. Applications are run in user mode and OS kernel, device drivers are usually run in superviser mode.
I am not very familiar with vxWorks but I believe your program is actually compiled as a downloadable kernel module. So I assume it must be running in kernel mode as well which means your program can misbehave and kill the entire system if you are not careful (e.g. run away pointers). BTW, you can do pointer arithmetics in C/C++. There is no need to do that in assembly. But if you are not careful, you can trash memory. For vxWork, you can probably trash kernel mode memory as well and cause a system crash. For Windows application, for example, a run away pointer can only trash application memory. Kernel mode memory is protected from applications. So your application may crash but the OS will be fine. You can just kill the app and move on. However, for Windows kernel mode drivers, they have privilege to access kernel mode memroy. If they have a run away pointer, they could trash kernel mode memory and bring the system down (Blue-Screen aka BugCheck).
Unread 05-04-2011, 20:05
mikets's Avatar
Software Engineer
BTW, there is no AT&T syntax, you probably meant Intel syntax. Also. there is no IA32 system. There is IA64 but 32-bit system is called x86. IA64 is an entirely different 64-bit architecture from Intel. The curent 64-bit Intel processors x64 is different from IA64 (Itanium). All new Intel processors are now 64-bit processors but they are backward compatible with 32-bit (x86) systems.
Unread 05-04-2011, 20:49
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
According to Intel there is http://www.intel.com/products/processor/manuals/
And I read that Intanium was the one that was NOT compatible with x86, that is why Intel uses AMD's x86-64 architecture.
