Go to Post Building a robot is one thing - but the fun I have had with my mentors, parents, and other students on team outings is something I cherish. - SuperJake [more]
Unread 16-03-2011, 21:32
CNettles11's Avatar
CNettles11 CNettles11 is offline
AKA: Chris Nettles
FRC #3502 (Octo-Pi-Rates)
CNettles11 is a jewel in the roughCNettles11 is a jewel in the roughCNettles11 is a jewel in the roughCNettles11 is a jewel in the rough
re- reconfigure robot radio after regionals?
Our robot radio was configured at the radio kiosk at the FRC Regional that my team went to, and it seems that we can no longer connect in AP mode. Does anyone know how to re- reconfigure the radio for use in AP mode?
Unread 16-03-2011, 22:00
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: re- reconfigure robot radio after regionals?
You could just reset and re config following the manual.
http://www.usfirst.org/uploadedFiles...adio_Rev_A.pdf
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 16-03-2011, 22:03
Electrical Engineer
Rookie Year: 1995
Follow the directions here (I suggest you start with a full reset of the radio to default settings per page 5) and you should be back in business...
Mike Betts
As easy as 355/113...
Unread 16-03-2011, 22:04
Just turn off wireless security.
It was set for the competition field with a team specific passcode.
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
Your radio was setup with a WPA security key at the regional. You can either log into the radio control panel and disable WPA encryption, or like Mk. 32 said, just reset the radio completely and start over.
Unread 16-03-2011, 22:52
RoboTigers1796 RoboTigers1796 is offline
FRC #1796 (RoboTigers)
RoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of light
To save yourself the trouble of going through the entire setup process again just plug a computer right into one of the ports on the back of bridge with an ethernet cable (make sure bridge is in AP mode)
Then open a browser, go to 10.xx.yy.1 (xx.yy being your team number, so im assuming 10.35.56.1 should work for you) username should be admin with no password.
go to manual set up of wireless and either see your passphrase to get onto the network or disable the security all together (disabling would probably be smarter for easy access by you and future volunteers at your next event).
2014 Attended: NYC Regional, SBPLI Regional NYC Regional- Imagery Award in honor of Jack Kamen
2013 Attended: NYC Regional, SBPLI Regional, FIRST Championships NYC Regional- Gracious Professionalism Award sponsored by Johnson & Johnson,SBPLI Regional- #4 Alliance Captain & Regional Winner- With our impeccable alliance 358 and 3171
2012 Attended: NYC Regional, SBPLI Regional, FIRST Championships NYC Regional- #7 Ranked Seed & Semi-Finalists, SBPLI Regional- #3 Seed & Regional Winner- With our very awesome alliance 527 and 870, Industrial Design Award sponsored by General Motors
2011 Attended: NYC Regional, SBPLI Regional SPBLI Regional- Xerox Creativity Award and #5 Alliance Captain
2009 Attended: NYC Regional, FIRST Championships NYC Regional Winner- With our amazing alliance 1807 and 56
Unread 16-03-2011, 23:21
CNettles11's Avatar
AKA: Chris Nettles
well, completely resetting the radio seems to be the easiest solution, and i'll know what the settings for the radio will be.
Thanks!
Chris Nettles
Team 3556
Unread 21-03-2011, 02:08
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Keep in mind that you still have to change the settings after resetting.
Just follow the posted document in the kit of parts website and you'll be fine.
Unread 21-03-2011, 03:48
Navid Shafa Navid Shafa is offline
FIRST Hiatus/Retired?
Navid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond repute
I am figuring that the answer is yes, but do we have to re-configure at a second regional or additional event? Not like it takes a long time, but it would be certainly nice to know if we can skip this step this weekend.
Thanks!
2015 & 2016 Fantasy FIRST Champions [Rotten Fruit Alliance]
Elgin Clock Award Winners: '13, '15, '16
Team 1983 | Alumnus, Former Mentor| Team_ 360 | Former Coach | Team 5803 | Former Mentor
"Once a Skunk, Always a Skunk"
Founding Member
Unread 21-03-2011, 03:56
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
I made a fatal mistake of assuming that the "Save Configuration" on the DLink can be used to restore the configuration of the router. So after we did the field wireless configuration, I "saved" it to a file on the laptop and then resetting and reconfiguring the router to our original setting so the team can still control the robot wirelessly in the practice field. And before our match, I would restore the router configuration to the "saved" field configuration. Boy was I wrong. We ended up totally disabled on our first match because there was no communication. Fortunately, we have a second router. So we now have one router configured to the field and another router configured for practice. We just swap the routers back and forth. Painful lesson to learn.
Unread 21-03-2011, 07:40
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
Thanks!
Yes, the WPA encryption keys are generated at the event and are unique to that event. You should still get your radio reprogrammed at your next event.
Unread 31-03-2011, 16:36
Team 2524 Team 2524 is offline
FRC #2524
Team 2524 is an unknown quantity at this point
We are having similar issues connecting wirelessly to our Dlink radio. After the NY Regionals, we figured that there was something wrong with it because we couldn't connect without having it tethered.
I thought there was something wrong with my laptop and i kept changing the last number of the IP address to see if that was the problem.
So We reset the radio and still cannot get it to work. According to the tutorial, All we have to do is reset again and change the "wireless security mode" on page 7 to get it to work?
Unread 31-03-2011, 16:47
Did you make all the settings that are required after a reset?
Security is optional. If you don't know how to use it, then I wouldn't bother with it. I don't use it myself.
Unread 31-03-2011, 18:19
andreboos andreboos is offline
FRC #3021 (The Agency)
andreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the rough
I've found that even after resetting the wireless security settings the wireless still doesn't work. This caused our team a great deal of confusion last year. The solution is simply to hardware-reset the device and go from there.
Unread 01-04-2011, 13:38
FRC #2524
How do you exactly hardwire-reset the radio?
I thought that you could only reset it from behind the radio by pressing the reset button.
