Go to Post Pictures are worth a thousand words... cell phone pics are worth 750. - kramarczyk [more]
Unread 16-03-2011, 23:07
nick_sheets nick_sheets is offline
FRC #3569
Team Role: CAD
nick_sheets will become famous soon enoughnick_sheets will become famous soon enough
Minibot weight?
Hey teams,
we were wondering what weight do you have to have the minibot at in order to drive it via direct drive rollers at .375 od?
ours is currently overweight in this area.
thanks!
Unread 16-03-2011, 23:08
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Re: Minibot weight?
we're running around 2.4 lbs.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 16-03-2011, 23:43
pfreivald's Avatar
AKA: Patrick Freivald
Re: Minibot weight?
Battery + motors + as little else as you can possibly manage.
Another consideration besides weight is normal force against the pole -- enough to get good traction but not so much that it adds much torque. This is a CRITICAL consideration, if our fooling around (erm, I mean, prototyping) means anything...
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 17-03-2011, 08:14
1708xMr.Roboto's Avatar
1708xMr.Roboto 1708xMr.Roboto is offline
Eddie
AKA: Eddie
FRC #1708 (AMPED Robotics)
Team Role: Driver
1708xMr.Roboto will become famous soon enough
Send a message via AIM to 1708xMr.Roboto Send a message via MSN to 1708xMr.Roboto
Re: Minibot weight?
Team 1708's Mini Bot is running around 2.4 pounds w/ Battery.
Facebook 1 - Chief Delphi 19382193
Unread 17-03-2011, 08:48
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: Minibot weight?
Originally Posted by nick_sheets View Post
Hey teams,
thanks!
What weight are you at?
The way to calculate the weight is to try to roughly balance the peak power torque with your wheel diameter.
To do this take the peak power torque (you can use the search function and find the thread for the dyno data). Make sure you include both motors. Multiply by an efficiency factor of 0.8-0.9 (this is a guess but should be utilized to keep on the positive side of the power curve). This is the resultant torque. Then divide this by the radius of the roller, and you have the max weight condition for that size roller to still achieve peak power. Note the motors can provide more torque than this at lower speeds, but you will be on the stall side of the power curve (dangerous). If you stay on the positive side of the power curve, your minibot will be less weight sensitive, but also not fully optimized.
