#151
Re: Team Update #18
#152
Re: Team Update #18
#153
Re: Team Update #18
to trip it, you have to be traveling ~.39 meters per second or ~1.28 fps for a 1 kilogram minibot using EBE assuming no friction, the minibot is not back driving, there is no rotational inertia, and pretty much everything else.
pretty much if you're not going that fast you are not winning anyways (~15 sec with more rounding and constant acceleration) |
#154
Re: Team Update #18
Please explain your reasoning and show your calculation. |
#155
Re: Team Update #18
I'm not so sure it's that simple Ether. Such a simple model isn't explaining what's being seen on the field. Additionally, why a 1/4" stop? Why not 3/4", which may be just as valid a distance that prevents the sensors from triggering (I'm assuming the plates are ~1" apart, which may be wrong since I still haven't examined the field drawings).
Additionally, how does your model take into account any mechanical (dis)advantage that plate exerts due to binding on the bolts opposite the minibot's impact point? |
#156
Re: Team Update #18
And BTW Linux == Embedded, my company has put it on several satellites and on some tiny tiny platforms. Linux does soft real-time quite well these days and is closing in on hard real-time performance. HTH |
#157
Re: Team Update #18
474 newtons is the equivalent force of an FLLer (~100 pounds) standing on the plate. |
#158
Re: Team Update #18
... or Karthik. Sorry, I couldn't resist. |
#159
Re: Team Update #18
Re: Team Update #18
Re: Team Update #18
Our team, like most, did not query the "customer" about a vague requirement. This is totally "our bad" though one hopes FIRST does not intentionally put out vague specs. Our first heavy-ish 4 second minibot triggered the sensors every time in week 1 at The Alamo but our evolving optimized minibot design is now gonna be a little stronger and stay in contact with the plate a little longer than originally designed. |
#162
Re: Team Update #18
I think Cory's point is that FIRST shouldn't be let "off the hook" every time they do something at the expense of teams just because it's a volunteer organization. We do still pay to compete, after all.
#163
Re: Team Update #18
You're basically saying that it's OK to imply an assumption for the calculation and then ignore the assumption for the conclusions of overall system characterization. You did this with your Mecanum analysis a few months ago as well. Quote:
Honestly, the only concession FIRST can make at this point is to give us dedicated MINIBOT time on Thursday. 4 teams at a time can have their MINIBOTs climb, uninhibited, yet with the real field's triggering/scoring system. If it's dedicated minibot time, then every team should be able to test their ascent and triggering 4-5 times in an hour or two. Last edited by JesseK : 17-03-2011 at 09:39. |
#164
Re: Team Update #18
If the specs are not written clearly, it is ALSO our responsibility to request clarification or we risk NOT getting paid (or tripping the sensor). |
#165
Re: Team Update #18
Proximity sensors and light sensors are two common proposed solutions.
Personally, I don't see what's wrong with a photo finish here. Yes, "instant replay" is a dirty word, but it would clearly be the best. |
