Minibot motors/fuses
We have burned out our minibot motors since ship day, and we want to try to make sure that we don't burn any out during competition, since they're 50 bucks a set.
Does reducing the amperage of the fuse in the battery actually help? I don't know a lot about electronics. If we put in a smaller amperage fuse, will it blow when the motors stall, before the motors burn out? What amperage fuse should be used, instead of the original 20 amp fuse? |
Re: Minibot motors/fuses
We used 3 and 5 amps last weekend. No motors blown!
3 and 5???
![]() Last edited by Teched3 : 17-03-2011 at 19:32. Reason: Added info |
By "use PTC leads", I recommend the motor power cable that includes the thermal circuit breaker. We use these, and changed to a 5A fuse, and have not had problems.
http://www.legoeducation.us/store/detail.aspx?ID=2135 Good luck! -Jeff |
If we switch to a 5 amp fuse, is it necessary to get the thermally protected motor cables? Will they help us substantially, or will the 5 amp fuse take care of the problem?
#7
We had both 3 and 5 amps available. We swapped them out and they both worked. We didn't put 2 fuses in at once.
