Go to Post Lesson learned: don't hide cables where drills can find them! - Richard Wallace [more]
  #211   Spotlight this post!
Unread 17-03-2011, 18:49
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Re: Team Update #18
You're forgetting about interrupts. If the switch is connected to an IO port which can be configured to generate an interrupt then there is no sample rate involved.
I considered interrupts, but even interrupts have a minimum latch time on most systems I've used, it may be on the order of microseconds, but it's there, and the point is, it was omitted, so we don't know if it's a fast interrupt or a slow poller, or a shift register that only gets clock in every 300ms, etc. The system must have some time component to it, which was my point. To assume it can behave instantaneously was erroneous, especially since no time component was specified. If you told me it took 100us for the interrupt to latch and take hold, then I'd say it's a negligible amount of time, but at least I'd have concrete evidence to work with.
EDIT: As also pointed out before, even interrupts cannot guarantee a clean signal without some decent debounce time on the signal, which still brings you back to a time component. Which we weren't given, and FIRST may not (yet) have.
Matt
Matt Krass
Last edited by Matt Krass : 17-03-2011 at 18:53. Reason: Additional point about debounce
  #212   Spotlight this post!
Unread 17-03-2011, 19:05
AdamHeard's Avatar
Lead Mentor
Re: Team Update #18
16.8 watts max power output w/o gearhead
= 12.4 ft-lb/sec
x2 motors = 24.8 ft-lb/sec max power output
2.3 lb estimated robot weight
(24.8 ft-lb/sec) / (2.3 lb) = 10.8 ft/sec (neglecting friction)
Beat me to it. We ran the math in metric units, but it's the same nonetheless.
We then assumed instant acceleration, and used distance = velocity x time to solve for an approximate "perfect" time.
  #213   Spotlight this post!
Unread 17-03-2011, 19:20
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Re: Team Update #18
Originally Posted by Paul Copioli View Post
I guess I just found the entrance music for Karthik at Waterloo! I wonder how long it will take before someone shuts down the webcast at Waterloo?
It'd get shut down a lot faster if we went with my own personal choice of entrance music, Shots by LMFAO.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
  #214   Spotlight this post!
Unread 17-03-2011, 19:38
Re: Team Update #18
For reference I'm linking to a post made a couple hours earlier here in this thread.
  #215   Spotlight this post!
Unread 17-03-2011, 19:42
Matt Krass's Avatar
AKA: Dark Ages
Re: Team Update #18
I recall your post, though I don't think my post was unqualified, merely incomplete. I should have mentioned interrupts in my original post, I was thinking more conceptually (against the notion of instantaneous detection taking zero time) and didn't see much relevance at the time.
Matt
Matt Krass
  #216   Spotlight this post!
Unread 17-03-2011, 19:56
Re: Team Update #18
= 12.4 ft-lb/sec
Continuing the calculation:
(16.8 watts @ max power)/(0.0475 Nm torque @ max power) = 353.7 radians/sec shaft speed @ max power
(10.8 ft/sec)/(353.7 radians/sec) = 0.03045 ft shaft radius = 0.73 inch shaft diameter (for direct drive)
Probably want to reduce that diameter by 15% or so for losses and margin
someone please check my math
  #217   Spotlight this post!
Unread 17-03-2011, 20:01
Re: Team Update #18
Poor word choice on my part; the word has multiple meanings which could be taken the wrong way. I intended definition #2:
un·qual·i·fied (n-kwl-fd)
adj.
2. Not modified by conditions or reservations; absolute
I referenced the previous post mostly for the remarks about debouncing interrupt-serviced switches.
  #218   Spotlight this post!
Unread 17-03-2011, 20:29
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Re: Team Update #18
Folks,
If I were to carefully read this entire thread, instead of only quickly scanning the last 100 or so posts, what useful information/conclusions would I acquire?
I have gathered that the tower targets are close to FUBAR status and many mini-bot designs are consequently pseudo-randomly finding themselves up the proverbial creek. It that all we have here?
My goodness, does it take 200+ posts of grouching at each other, and at FIRST, to convey that clearly?
I know everyone is tired, but this could be a fun topic.
Who has tested some work-arounds and can reports their results to teams that need to modify their mini-bots???? Is slower better? Would putting a broad squishy nose on a mini-bot help? Would leaving the mini-bot motors energized an extra few fractions of a second after target-contact help? Anything else?
Blake
  #219   Spotlight this post!
Unread 17-03-2011, 20:32
Matt Krass's Avatar
AKA: Dark Ages
Re: Team Update #18
Originally Posted by gblake View Post
Folks,
Blake
I don't believe this has been 200 posts of people grouching at each other, instead it's been a very lively, interesting debate of the technical details of the situation. And since this is just coming out now, nobody has publishable results yet, just a lot of hypotheses on what may or may not be occurring, and how to possibly improve the towers or minibots.
Nobody has a definitely answer for you, other than expect to have to work at this some more.
Personally I think this group has done a fantastic job dissecting the situation and working to figure out the information FIRST has woefully failed to provide once again, but give them a chance, this isn't old news yet.
I thought it was a fun topic, though I wish I could contribute more effectively to it.
EDIT: I wanted to answer to this as well.
Sorry to misunderstand you, your intended wording makes a lot more sense!
Matt
Matt Krass
  #220   Spotlight this post!
Unread 17-03-2011, 20:39
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Re: Team Update #18
There is a large number of posts because it is a topic of interest and importance to everyone, not because folks are looking to grouch at each other. The volume, to which you have contributed, is an accumulation of many individuals, of which you are now one. It is the result of many people sharing their 2 cents, like you did. Nearly every post has dealt with the topic, the only one I've read that really grouched at others is yours.
  #221   Spotlight this post!
Unread 17-03-2011, 23:14
boomergeek's Avatar
boomergeek boomergeek is offline
AKA: Mr. D (Dick DiPasquale)
FRC #0241 (Pinkerton Robotics)
boomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant future
Re: Team Update #18
= 12.4 ft-lb/sec
Here's a different way to get at approximately the same point.
At kick off, the video of the FIRST built minibot showed about 1.3 ft/sec for a robot that looked to be more than 5 lbs and using a pair of Tetrix motors and gearboxes.
Its not hard to cypher that a 2 lb robot can be 2.5 times faster than a 5 lb robot. By the same token, if you throw away a near 50% inefficient transmission, you should be able to obtain another doubling of speed. That gets you in the 7-8 ft/sec range. Add additional lowering of friction in the attachment to the pole mechanism and you approach the magically 10.8 ft/sec. Add topping off the battery to get to a better motor curve is gravy on top.
  #222   Spotlight this post!
Unread 17-03-2011, 23:23
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire (on sabbatical))
Re: Team Update #18
Just as a note:
We had 3 minibots up the pole today at the Detroit district, all three triggered just fine. I'll keep my eye on it this weekend.
  #223   Spotlight this post!
Unread 18-03-2011, 00:08
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Team Update #18
Originally Posted by Chris Hibner View Post
Just as a note:
Were any additional modifications made to the towers since the last time this field was used? What was the last event this field was used at?
  #224   Spotlight this post!
Unread 18-03-2011, 01:30
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Team Update #18
= 12.4 ft-lb/sec
Thank you Ether! This is the first post I've seen all season to do a proper (yet quite simple) calculation of how fast a minibot of given weight can get up the pole. I've been meaning to do this with my students all season long, but was too busy with the arm and other things. I think now is the time to revisit it.
Trial and error is one thing. Knowing what you're shooting for, because you did some calculation first, is quite a different (and much better) thing.
  #225   Spotlight this post!
Unread 18-03-2011, 06:58
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Team Update #18
The field from Waterford went to Detroit.
(since 2004)
