Go to Post The purpose of this forum is for us to communicate our ideas, so that we can collectively strengthen our ability to inspire others. - Jaine Perotti [more]
Unread 18-03-2011, 02:21
cmass cmass is offline
FRC #1189
cmass is an unknown quantity at this point
Pneumatics Help
Vexing pneumatics problem ...
Have 5 festo M7 2 way solenoid valves in a gang ... all are singles. All are hosed and wired in similar / same manner.
We are having trouble with one of the 5 valves:
- our code can change the status light from a side (extend) to b side (retract)
- the manual actuation can physically change the output of the valve from extend to retract
- when we change state with code through the solenoid breakout, the light changes but the spool does not seem to move
- we replaced the valve twice with no impact
I'm thinking solenoid breakout, wiring but I cannot explain the light changing state but no apparent or observed movement in the spool.
Unread 18-03-2011, 08:06
Re: Pneumatics Help
If the coil is wired backwards, then the light will go on, but the coil won't work.
Unread 18-03-2011, 11:06
quinxorin quinxorin is offline
Mentor now :(
AKA: Ian Pudney
quinxorin will become famous soon enough
Re: Pneumatics Help
If changing the direction does not work, try connecting the leads directly to a 12v battery (both directions) to make sure it works. There is a chance (very low) that the solenoid coil is fried.
The manual button is not a good indication of whether the solenoid works because, on most valves, it physically moves the solenoid, rather than with electricity.
"Sed res docuit id verum esse, quod in carminibus Appius ait, fabrum esse suae quemque fortunae."
- Every man is the architect of his own fortune.
