Go to Post Analysis is a tool. Like any other tool you need to figure out where and when to use it. That's the tricky part. - ChrisH [more]
Unread 17-03-2011, 17:17
Minibot Falling off pole - Penalty?
At bayou, the refs are calling a penalty for any instance where a minibot falls off the pole. Is this happening at other regionals? I've seen many a minibot fall off at other regionals, sans penalty.
Thanks
Unread 17-03-2011, 17:59
Chris's Avatar
Chris Chris is offline
So apparently it hangs......
AKA: Chris Carnevale
FRC #0177
Chris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond repute
Re: Minibot Falling off pole - Penalty?
Wasn't a penalty at WPI or BAE.
Our mini-bot went flying off the pole every-time.
Chris C.
Team 151 | Alumni | 2000-2002 | Nashua High School
Team 229 | Alumni | 2003-2006 | Clarkson University
Team 148 | Alumni | 2007 | RackSolutions.com
Team 177 | Engineer | 2008-? |
Unread 17-03-2011, 18:02
GaryVoshol's Avatar
GaryVoshol GaryVoshol is online now
Cogito ergo arbitro
You might ask them what rule they are using to call that penalty.
(since 2004)
Unread 17-03-2011, 21:10
DonRotolo's Avatar
Back to humble
FRC #0832
If it falls off before the end buzzer I can think perhaps
<G42> ROBOTS, MINIBOTS, or HOSTBOTS may not intentionally detach parts or leave MECHANISMS on the FIELD (with the exception of appropriate DEPLOYMENT of the MINIBOT). Violation: PENALTY for each incident and potential RED CARD if an intentionally detached COMPONENT or MECHANISM impedes MATCH play.
BUT Only if combined with
<G46> MINIBOTS may only be used to climb the TOWER. Violation: YELLOW CARD
The theory here is that a minibot on the carpet is not being used to climb the tower, but that's specious at best.
Alternatively, if the minibot falls far enough from the HOSTBOT
<G40> ROBOTS or HOSTBOTS may not exceed PLAYING CONFIGURATION at any time. Violation: PENALTY for unintentional, momentary violations. RED CARD for intentional or continuous violations.
This was never called at NJ
Unread 17-03-2011, 21:13
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
I would just have your team captain or coach walk up to the head referee in the morning and say you were looking through the rules and could not find this penalty and ask that he point it out to you. I would also bring a copy of the game manual with me. I have done this plenty of times at various events and the refs are always very nice about it and most of the time I am wrong and they are right but in this case it looks like the ref might be in the wrong.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 18-03-2011, 00:19
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
There is a blue box under <T14> that allows for invoking <G26> ultimately resulting in a penalty, thus, a referee can indeed give penalties for falling minibots, AND this is entirely at the discretion of the head referee
Unread 18-03-2011, 01:44
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Hrrmm. There might be some design adjustment in order. It seems to me that even for the magnet stick-on ones, some thin polycarb could solve the falling off issue, without causing any friction, or deployment issues. Just something that flexes around the pole when putting it on, and comes around the other side of it, to keep it from falling off.
Unread 18-03-2011, 02:03
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
That's preposterous! the minibot falling off the pole is a punishment within itself.
Unread 18-03-2011, 02:34
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
<G26> is a gameplay rule that covers safety violations. Presumably—and admittedly this isn't actually explained clearly—it would only be invoked if safety was jeopardized during gameplay.
I'm not sure why there's a blue box invoking it in this circumstance. (The blue boxes "are not part of the formal rules, and do not carry the weight of [the] rule[s]".) If it's egregiously unsafe, the referees have the option to award a <T06> or <T09> card anyway, irrespective of what the blue box talks about.
Unread 18-03-2011, 06:42
GaryVoshol's Avatar
Cogito ergo arbitro
There is a blue box under <T14> ...
No need to shout at us.
<T14> is in the Field Reset section of the manual. Reading of the rule itself will show that the rule was meant to make removal of the Minibot safe. If it falls off itself during the match, there is no safety issue.
(since 2004)
Unread 18-03-2011, 07:52
Brandon Holley's Avatar
We implemented exactly this solution on ours. It works rather well but there's still instances where it can fall off after coming back down.
I watched many webcasts through weeks 1 and 2 and saw many minibots fall off the pole, especially after they had triggered the target. Its frustrating to constantly have to modify our design based on different interpretations of the rules. Obviously it would be nice if the minibot stayed on the pole every single time, but the way I read the rules I don't think its require to.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 18-03-2011, 08:25
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
To me, this seems like a good situation in which to apply the guidance contained in yesterday's Bills' Blog concerning mis-communication at FRC Events:
...If you encounter a miss-communication at any FRC events in the future, please turn to the 2011 Manual first, then with rule in hand, discuss the problem with the event volunteer. If you cannot come to an agreement, go to the Event Manager or FTA both of whom can contact FIRST HQ if they can’t resolve the issue themselves.
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Unread 18-03-2011, 10:27
Update: Our team spoke to the head ref this morning about the rule and he informed us they would not be calling this as a penalty afterall. Thanks everyone for the input.
Unread 19-03-2011, 00:28
AKA: Alan Wells
FRC #1350 (Rambots)
1) I wasn't shouting, I was emphasizing the important stuff. When I shout I use exclamation points.
2) Even when <T14> isn't a factor, <G26> can still act alone.
Unread 19-03-2011, 09:45
Glad to hear that the issue was resolved!
I also noticed (at least as well as could be seen from the webcast) that it seemed that 125 was successfully deploying the minibot yesterday without it falling off the pole! (Or, if it was falling off the pole, it was doing so after crash-landing on the base at the bottom.)
