Go to Post Super Bowl, P-Diddy, Diet Pepsi. Super Bowl of Smarts, Dave Lavery, Diet Coke. - Gary Dillard [more]
Unread 17-03-2011, 17:43
implosionprez's Avatar
implosionprez implosionprez is offline
AKA: Ty
FRC #2484 (Team Implosion)
implosionprez is an unknown quantity at this point
Minibot motors/fuses
We have burned out our minibot motors since ship day, and we want to try to make sure that we don't burn any out during competition, since they're 50 bucks a set.
Does reducing the amperage of the fuse in the battery actually help? I don't know a lot about electronics. If we put in a smaller amperage fuse, will it blow when the motors stall, before the motors burn out? What amperage fuse should be used, instead of the original 20 amp fuse?
Unread 17-03-2011, 18:07
cgmv123's Avatar
cgmv123 cgmv123 is online now
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Minibot motors/fuses
We used 3 and 5 amps last weekend. No motors blown!
AKA: Ty
3 and 5???
Unread 17-03-2011, 19:23
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Minibot motors/fuses
Use the PTC leads allowed to feed the motors, and start with a low amp fuse on the main battery fuse - say five amps and work up to seven amps or so. Hard to advise since we don't know your minibot weight, or what speed you are using to climb the pole. the larger the drive wheel, the greater the amp draw for the same weight. reduce weight, increase wheel diameter to get you to run at maximum power. Look for the motor curves in the Manual documentation.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 18-03-2011, 07:00
jreuter jreuter is offline
FRC #1073 (Force Team)
jreuter has a spectacular aura aboutjreuter has a spectacular aura about
By "use PTC leads", I recommend the motor power cable that includes the thermal circuit breaker. We use these, and changed to a 5A fuse, and have not had problems.
http://www.legoeducation.us/store/detail.aspx?ID=2135
Good luck!
-Jeff
Unread 18-03-2011, 16:47
AKA: Ty
If we switch to a 5 amp fuse, is it necessary to get the thermally protected motor cables? Will they help us substantially, or will the 5 amp fuse take care of the problem?
Unread 18-03-2011, 17:26
cgmv123's Avatar
AKA: Max Vrany
We had both 3 and 5 amps available. We swapped them out and they both worked. We didn't put 2 fuses in at once.
