Go to Post My teams robots have been good, bad and ugly BUT they were all beautiful because they were there. - JohnBoucher [more]
Unread 18-03-2011, 13:25
SoulSaber1's Avatar
SoulSaber1 SoulSaber1 is offline
AKA: Drew Parker
FRC #3011 (RoboWarriors)
SoulSaber1 is an unknown quantity at this point
Bit of coding help
So, for autonamous we are using a modified line tracker code, with certain cases for different scenarios. After this loop we want the robot to go backwards, but we can't seem to make it happen.
case 7: //ALL SENSORS ON *OR* MAYBE AT CROSS
                        if (time > stopTime)
                            atCross = true;
                            speed = 0;
                            gripper.set(false);         //Closes gripper
                            gripper2.set(true);         // "     "
                            while (backCount < 5)
                                backCount++;
                                drive.arcadeDrive(-.5,0);
Any ideas?
"I don't care about what anything was DESIGNED to do, I care about what it CAN do." -Gene Kranz
"This lifestyle is DIY or GTFO" - lucid
Unread 18-03-2011, 13:32
Egg 3141592654's Avatar
Egg 3141592654 Egg 3141592654 is offline
Now a mentor, always a student
FRC #0810 (Mechanical Bulls)
Egg 3141592654 is on a distinguished road
Re: Bit of coding help
If you want the robot to move backwards, instead of using a while loop, replace with something like...
drive.arcadeDrive(-.5 , 0);
Timer.delay(/*insert time you want to go backwards in milliseconds*/);
drive.arcadeDrive(0 , 0);
To answer why your robot may not be moving backwards, the loop might be cycling too fast for you to actually notice, so 5 cycles would be instant. Remember to put the drive.arcadeDrive(0 , 0) or else your robot will keep driving backwards. Good luck out there!
"The answers to the book of life are not found in the back." Charlie Brown
Software Mentor - Team Apex Robotics 5803
Lead Programmer - Team 810 Mechanical Bulls '09-'11
Unread 18-03-2011, 14:04
SoulSaber1's Avatar
AKA: Drew Parker
For some reason this isn't working either. did you mean like this?
                            atCross = true;
                            speed = 0;
                            Timer.delay(1.0);
Unread 19-03-2011, 13:06
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
                            atCross = true;
                            speed = 0;
                            Timer.delay(1.0);
Okay so I can see one clear problem here I think.
Timer.delay is generally in milliseconds so you have it going backwardsfor 1 millisecond then stopping. Try increasing Timer.delay to a greater value, say 500, then try it again.
Remeber if it goes berserk and doesnt stop for some reason you have a stop button.
Unread 21-03-2011, 11:24
Timer.delay for wpilibj is in milliseconds, so 1 second would be
Timer.delay(1000);
Unread 21-03-2011, 17:26
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Robby Unruh will become famous soon enough
Timer.delay(1000);
The javadoc only says this:
delay
public static void delay(double seconds)
Pause the thread for a specified time. Pause the execution of the thread for a specified period of time given in seconds. Motors will continue to run at their last assigned values, and sensors will continue to update. Only the task containing the wait will pause until the wait time is expired.
Parameters:
seconds - Length of time to pause
Note; "seconds". I'm pretty sure it's just in normal seconds. So one second would be
Timer.delay(1.0); // only accepts doubles as an argument
My team has had no problems using this, as opposed to using milliseconds(?).
However, when using other functions in the Timer class, like get(), it will return in microseconds. For our minibot deployment, we start a timer and have a condition timer.get()/1000000 > 110, if true it will deploy. If false, it'll let the user know you can't deploy yet.
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
