Go to Post How easy will it be for a driver to control 5-6 different motions at once? Most drivers only have two hands. - Kevin Sevcik [more]
View Poll Results: What do you use for chassis material?
wood 11 5.07%
steel angle 8 3.69%
aluminum angle 36 16.59%
steel tubing (round or rectangular) 2 0.92%
aluminum tubing (round or rectangular) 58 26.73%
Bosch extrusion or similar (aluminum or steel) 89 41.01%
Other 13 5.99%
Voters: 217. You may not vote on this poll
  #31   Spotlight this post!
Unread 14-11-2002, 22:17
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Re: Chassis
Originally posted by maclaren
Polycarb on the other hand is extremly tough...
Unless you effect it chemically. In 2001 my HS team had forklifts made out of 1/4" lexan. We spray-painted them so that the drivers could easily see them from the booth. Late in the day at Long Island, we had a minor collision with 263 (they blasted right into us coming into the endzone) and the forklifts shattered.
Near as we can figure, the Lexan was weakened by the spray paint.
Moral of the story:
Don't paint Lexan. It can weaken it greatly.
  #32   Spotlight this post!
Unread 14-11-2002, 22:55
maclaren maclaren is offline
AKA: Dexter
FRC #0997 (Spartan Robotics)
maclaren is a glorious beacon of lightmaclaren is a glorious beacon of lightmaclaren is a glorious beacon of lightmaclaren is a glorious beacon of lightmaclaren is a glorious beacon of light
Lightbulb
That is a very good point to not paint lexan. Generally plastics dose not like to be sprayed with solvents(which spray paint is). They tend to weaken them by eating little holes in them. Thus, as you know, they become weak and brittle. 1/4" Lexan is about the weakest lexan you can find. The lexan used in the demo was most likly of 3/4" to 1" thick lexan.
  #33   Spotlight this post!
Unread 15-11-2002, 00:40
patrickrd's Avatar
patrickrd patrickrd is offline
AKA: Patrick Dingle
patrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to behold
Send a message via AIM to patrickrd
Re: Re: Chassis
Moral of the story:
Are you sure this was Lexan? I have never heard of Lexan shattering, but acrylic would do exactly what you say. Certainly spray painting could have surface effects but by the molecular nature of polycarbonate I don't see how it could shatter, even if the surfaces are eaten away a little.
Systems Engineer - Kiva Systems, Woburn MA
Alumni, Former Mechanical Team Leader - Cornell University Robocup - 1999, 2000, 2002, 2003 World Champions
Founder - Team 639 - Ithaca High School / Cornell University
Alumni - Team 190 - Mass Academy / WPI
  #34   Spotlight this post!
Unread 15-11-2002, 00:58
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
First of all I don't see why you'd ever want to spray paint lexan as it's crystal clearness is beautiful as it is. Perhaps a custom airbrush job but I'll save that topic for another thread.
As for the lexan shattering, this is completely reasonable given the circumstances. The spraypaint acts as a solvent and attacks the lexan making it brittle. Pactra and Parma both make paints safe for lexan. They can be found at your local hobby shop. Here's the link for the Parma paint http://www.parmapse.com/faskolor.asp
  #35   Spotlight this post!
Unread 15-11-2002, 02:32
JVN JVN is offline
@JohnVNeun
Re: Re: Re: Chassis
Positive. It was the real stuff. It took quite the hit to break it, but still.
  #36   Spotlight this post!
Unread 15-11-2002, 19:43
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
We painted our Lexan panels last year. That's how we got the black color. We dented it a little, but it never broke (and it took some big hits, too).
Jeff Waegelin
  #37   Spotlight this post!
Unread 18-11-2002, 19:59
AKA: Dexter
The lexan that was spray painted and shattered was 1/4" thick this is important. Lets say that the paint eat away at the 1/16" deep(very conservative estimate) on all painted sides that leaves 1/8" of untainted material left to hold up to an impact. since the imapct was on there goal grabber forklift and it most likly was nt supported except on the end and it was probably over 10" long that leaves an 1/8" thick 10" long piece of unsupported lexan collideing on edge with an unforgiving piece of metal(most likly). Shattering sounds like the logical solution.
If you want to make your forklift visible I would have used a bright shinging tape. Like a neon yellow tape or what ever would match your bots color scheme.
  #38   Spotlight this post!
Unread 18-11-2002, 20:17
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Here is a pretty good website w/ Metric and English properties of polycarbonate (aka lexan).
http://www.matweb.com/SpecificMateri...&group=General
Purdue Alumni
Cummins, Inc.
  #39   Spotlight this post!
Unread 19-11-2002, 01:51
JVN JVN is offline
@JohnVNeun
This was the solution we came up with for Nationals.
  #40   Spotlight this post!
Unread 28-11-2002, 00:21
PMGRACER's Avatar
PMGRACER PMGRACER is offline
AKA: PAUL GIANNOSA
PMGRACER is on a distinguished road
Titanium?
We'd love to use all Ti plate and tube, but C & A might balk at the materials bill! So instead we've used the 1.5 x 1.5 extrusion in the past. There is a considerable weight penalty once you add all the hardware to put the frames together. I like how the Huskie Brigade designed this years bot. Using the shape of the Huskie as the primary structure. I also likes the Killer Bees chasis. Standing .156 plate on edge, connecting the plate with tube is strong and light. And as their leader says "some chasis flex helps keep the wheels on the floor.." Working with sheetmatal most of the time, I appreciate Wildstang's bot as work of art. It is amazing how strong thin sheets of aluminum become once you start putting bends and beads in them. The benfit of the extrusion is the rapid build and ease of maintenance once the bot is together. The trick now, is to use the modular concept for ease of assembly and modification, making the components durable enough for the application, but light as possible....I still want an all Ti bot....
Racing is an incurable addiction!!
  #41   Spotlight this post!
Unread 05-12-2002, 21:42
Steve Team 311 Steve Team 311 is offline
#0311 (Red Jammers)
Steve Team 311 is an unknown quantity at this point
The only sheet metal chasis?
.09" Sheet metal, oh yeah.
Team 311 Red Jammers East Islip NY www.eirobotics.com
  #42   Spotlight this post!
Unread 07-01-2003, 06:57
John Schineller John Schineller is offline
#0506 (StART-St. Anthony's Robotics Team)
John Schineller is an unknown quantity at this point
Question Aluminum Extrusion in Kit
We plan to use some of the aluminum extrusion in the kit this year. Has anyone found a marking on the box extrusion or a spec for the exact alloy of aluminum used. We need this for a compatible weld material.
Thanks
John Schineller
Team 506
StART
NASA/StAnthony'sRoboticsTeam
  #43   Spotlight this post!
Unread 07-01-2003, 08:19
George George is offline
#0060 (Bulldogs)
George is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to behold
We (60) use 1"x2" & 2"x2" 1/8 wall 6061 Aluminum tubing
(good weld-ability / good working) with a lexsan floor pan/side panels for the main frame
alum tubing / plate for components
6061--- yield strength is 40 ksi hardness is 95 brinell
melting range is 1080f to 1205f
also heat treatable (let cool Slowly or crystallizing may occur)
SEE statement below
watch the oz, the lbs take care of themselfs
  #44   Spotlight this post!
Unread 17-01-2003, 22:41
#0311 (Red Jammers)
Exclamation
Shhhhh... everyone keep this a secret, we use sheet metal .090 thick! But i'm not gonna tell you how we do it!
We have wanted to build a full sheet metal frame using 6061-t4 aluminum. We felt we could achieve a better strength to weight ratio.
  #45   Spotlight this post!
Unread 17-01-2003, 23:06
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
I'm really interested in seeing what sorts of results you all have with the sheet metal.
We're using .19" sheet metal for our frame, with some beefier stuff mixed in here and there. I was a little scared of going thinner than that. We'll see how it shapes up in a few weeks, I guess.
Good luck.
--Madison--
...down at the Ozdust!
Image Discuss: Team 190 - Completed chassis CD47-Bot Robot Showcase 17 20-02-2003 17:37
Image Discuss: Chassis Teaser CD47-Bot Robot Showcase 4 10-02-2003 23:00
the provided chassis material Andrew Dahl Kit & Additional Hardware 5 09-01-2003 15:26
Sheet Aluminum Chassis: fs_2002 Technical Discussion 4 17-10-2002 10:10
Chassis ark_1230 Technical Discussion 2 04-09-2002 22:51
