Go to Post Yay for teaching how to fish! - RoboMom [more]
Unread 18-03-2011, 17:02
MathFreak's Avatar
MathFreak MathFreak is offline
Team Leader/Electrical
AKA: Hikari Iwasaki
FRC #5701 (Indigo Ninjas)
Team Role: Electrical
MathFreak is on a distinguished road
Jaguars and Victors
What is the difference between jaguars and victors? For my robot we are using jaguars for the wheels and victors for the arms but I don't get the difference.
Hikari Iwasaki
2nd Grade student at Senior High school at Otsuka,University of Tsukuba
2014 Team5701 Team leader
2011 Team 296 Youngest team member
Team 5701 Indigo Ninjas
Website
Facebook
Twitter
Blog (in Japanese)
Unread 18-03-2011, 17:09
Chexposito's Avatar
Chexposito Chexposito is offline
AKA: Expo
FRC #1730
Chexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of light
Re: Jaguars and Victors
features in each controller mainly... victors are nice because they don't have a breaker in them, so they run as long as the power distribution board is giving it juice. you also have to deal with the fan wires. really most teams don't use the features in the jaguars, which pretty much levels them out besides the internal breaker, which is why that's probably on your arm... you draw more current when moving a long arm with a weight on the end than turning wheels...
Unread 18-03-2011, 17:33
NickE's Avatar
NickE NickE is offline
_
Both Jaguars and Victors provide basic speed control features. The Jaguars have advanced features such as CAN (Controller Area Network) which allows for more advanced control. However, the Victors are lighter and smaller.
Furthermore, the Jaguars have a "feature" that shuts them down for several seconds if too much current is drawn. The Victors do not have this.
Unread 18-03-2011, 17:45
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
1. There is no breaker in the Jauguars. There is, however, an overcurrent lockout, where the Jaguars will enter a fault condition (and turn off the connected motor) when the controlled motor pulls too much current for too long.
2. The Victors seem to be more reliable to me.
3. A drive will generally pull a lot more current than an arm:
Most drive systems have a total of 4 CIM motors in a one or two speed transmission. In a single speed, speed and torque are compromised, so when accelerating or pushing, the motors will draw large amounts of current (the CIMs stall at 133 amps). In a two speed it is a little better, although high gear acceleration will still draw huge amounts of current, low gear is usually traction-limited so the point where the wheels slip draws enough current for the breakers not to trip (so, if would be a max continuous power of 40 amps per motor, which is still a lot). An arm has one or two motors working together to drive a much more controlled load. It also usually has counter-balance to help it. A banebots 550 motor pulls 85 amps at stall, and in a properly designed arm, it generally never stalls for a considerable amount of time, because the FP and Banebots motors will smoke when stalled.
Kettering Motorsports
Unread 18-03-2011, 21:02
flameout flameout is offline
AKA Ryan Van Why
FRC #0957 (SWARM)
flameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to all
One thing that hasn't been mentioned is that the Jaguars are more linear.
In basic terms, they have much more precise control at low power levels than the Victors.
By the way, we're using Jaguars for drive (for the linearity) and Spikes for everything else (we have no need for any Victors on this robot).
Unread 18-03-2011, 21:14
MathFreak's Avatar
AKA: Hikari Iwasaki
and what are the difference between jaguars, victors and Spike?
We used 1 spike for compressor this year... but I don't know what that does either
Hikari Iwasaki
Website
Facebook
Twitter
Blog (in Japanese)
Unread 18-03-2011, 21:34
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Jaguars and Victors
A spike is like a light switch. No speed control. Jaguars and Victors are likened to a dimmer control.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 18-03-2011, 22:17
mrf555 mrf555 is offline
FRC #0555
mrf555 is an unknown quantity at this point
Our team had an issue with Jaguars constantly burning out, now 2 of our 6 motor controllers are Victors. We fried about 4 Jaguars this build season alone, and no Victors.
Unread 18-03-2011, 23:46
Chexposito's Avatar
AKA: Expo
FRC #1730
i was trying to put it into more simple terms... i know it's not a breaker, i just didn't want to explain all that...
Unread 19-03-2011, 00:12
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Our team and I believe most teams have found that Jaguars have better, smoother control at low speed and power, and more linear overall control. For fine motion control and position holding, we perceive them as better. For general purpose applications where fine low speed control is not needed, they have no particular advantage, and if fact Victors may have advantages (reliability, weight, size, etc.)
Unread 19-03-2011, 00:16
kws4000's Avatar
kws4000 kws4000 is offline
Team Mentor - Programming
AKA: Krazy Karl
FRC #2405 (Divided by Zero)
kws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the rough
The first year Jags came out, we jumped on them faster than you could say "better". They worked. The next year, we somehow lost some magic white smoke, via metal shavings and air cutter oil. This year, prit'near all contols are by Vics, except low power things, like gripper and wrist (black Jag) and minibot (Spike).
Mentoring:
1) Educating students on the ability to learn and have fun at the same time.
2) Giving back to those who made you who you are.
2009-2011 Student 2405 Electrical/Programming & Asst. Captain
2012-???? Mentor 2405 Programming/Jack-of-all-Trades
Unread 19-03-2011, 09:09
Jaguars do not have an internal breaker they have an over current sense which shuts down the output during a perceived fault. The Jags have a 15kHz switching frequency while the Victors have a 150 Hz switching frequency. This difference allows the output pulse to interact with the motor inductance to produce a smoother but less powerful motor response at low throttle levels. This phenomena while allowing a more controlled movement also produces less motor power for a given throttle value below about 60-75% of full throttle.
The Spike is simply two relays inside one case. They can be commanded in such a way that the output can be full on in either direction or each output pin can be controlled independently.
Unread 19-03-2011, 10:07
Chexposito's Avatar
AKA: Expo
FRC #1730
already discussed...
