Go to Post Reading Andy Bakers post- priceless :D - thoughtful [more]
  #241   Spotlight this post!
Unread 18-03-2011, 14:50
Miksoko's Avatar
Miksoko Miksoko is offline
AKA: Soren
FRC #2115 (M^3- Red Dwarf)
Team Role: Student
Miksoko is an unknown quantity at this point
Re: Team Update #18
Actually, that's quite good. You're right: any bot with the potential of winning the match (being the first to the top) will have enough velocity to trigger the pole. A lighter robot, unless it had an illegal battery or power source, would not have the velocity to create enough force, and the larger robot would being expending force on getting up the pole, therefore sacrificing velocity.
  #242   Spotlight this post!
Unread 18-03-2011, 15:24
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Team Update #18
Be aware that the calculation does not include any consideration of the time it takes the bot to accelerate to the indicated top speed. So if you use the top speed to calculate how long it will take to get to the top of the pole, the answer will be optimistic.
Keep in mind, there may exist a design in which the minibot is accelerated (reaching top speed) before it ever gets to the pole...
Originally Posted by jspatz1 View Post
This graph matches our experimental results. Our climb time was minimum at .40" dia.
But how much did your minibot weigh during this test, which found this diameter to be optimal?
  #243   Spotlight this post!
Unread 18-03-2011, 16:24
Josh Fritsch's Avatar
Josh Fritsch Josh Fritsch is offline
Team 27 Mentor/Alumni
FRC #0027 (Team Rush)
Josh Fritsch has a spectacular aura aboutJosh Fritsch has a spectacular aura about
Re: Team Update #18
Not sure if someone has updated everyone, but we have not had any issues at West Michigan so far
  #244   Spotlight this post!
Unread 18-03-2011, 18:50
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Re: Team Update #18
Peachtree update:
No false positives, no false negatives (that I witnessed). Every minibot that made it to the top of the tower triggered the tower. It looks like, for peachtree at least, all this worry was for naught.
Former Mentor Team 1771
Former mentor Team 4509
  #245   Spotlight this post!
Unread 18-03-2011, 19:07
pfreivald's Avatar
AKA: Patrick Freivald
Re: Team Update #18
Originally Posted by martin417 View Post
Peachtree update:
That's wonderful!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #246   Spotlight this post!
Unread 18-03-2011, 20:56
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Re: Team Update #18
Originally Posted by Lil' Lavery View Post
Just witnessed a false positive on the Bayou webcast. Minibot was about halfway up the tower when the lights triggered.
Impossible event since everything was fixed according to the update
  #247   Spotlight this post!
Unread 18-03-2011, 21:02
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Re: Team Update #18
I don't think so. When it grabs the pole it will slow down and then accelerate again. It can't climb faster than it can free spin or even travel horizontally, not on Earth anyways.
  #248   Spotlight this post!
Unread 18-03-2011, 21:37
Re: Team Update #18
I've seen a couple of teams (190 at WPI) with a clever deployment design that uses the same sized pipe curved to mate to the tower.
The minibot starts out accelerating downward off the hostbot (gravity a plus), then follows the curving pipe to start up the tower at full speed.
  #249   Spotlight this post!
Unread 18-03-2011, 21:44
boomergeek's Avatar
boomergeek boomergeek is offline
AKA: Mr. D (Dick DiPasquale)
FRC #0241 (Pinkerton Robotics)
boomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant future
Re: Team Update #18
<G19> MINIBOTS must remain completely autonomous and move up the POST solely through electric energy provided after the start of DEPLOYMENT by the permitted, unaltered battery and converted to mechanical energy by the permitted unaltered motors (and associated, appropriate circuitry). Violation: The TOWER on which the MINIBOT is DEPLOYED is disabled. If the MINIBOT is DEPLOYED on something other than a TOWER, then the ALLIANCE’S TOWER upon which the highest RACE SCORE was earned will be discounted.
<G19> means that HOSTBOTS are not allowed to launch the MINIBOT up the pole at the TARGET, or otherwise contribute to the vertical movement of the MINIBOT. Energy for vertical movement may not be stored in the MINIBOT before DEPLOYMENT (except that which is contained within the battery and excluding incidental kinetic energy stored in the motors or wheels, but NOT, for example, in a flywheel).
(My highlighting, not FIRST's)
Since DEPLOYMENT starts when the miniboot crosses into the cylinder, it cannot have energy other than "incidental" kinetic energy in the wheels.
Incidental horizontal running starts prior to crossing into deployment-i.e., the length of the minibot will probably be overlooked as incidental.
Converting the horizontal energy produced by the minibot while over the cylinder is allowed: so the speed at the point of crossing the start line for a ramp can be higher than a minbot that uses an arm to place the minibot on the pole. I think a ramp bot can reach a higher top speed but the question is how much faster can other mechanisms get the bot to the start line as compared to the ramp bot. If the non-ramp bots do not start with a significant lead, the ramp bots can pass them (Assuming equal efficiency).
Also of note: the ramp needs to be well below the start line such that none of the minibot is in contact with it when any of the minibot crosses the start line.
My bet is that a ramp bot will record the fastest time. (We do not have a rampbot: at least not yet )
Also of note: rampbots need to demonstrate that their hostbot does NOT provide horizontal momentum to the minibot: E.g., a host bot that suddenly decelerates as it is reaching the tower and is not completely motionless as it deploys the minibot COULD be imparting non incidental kinetic energy. Referees will need to watch out for that.
  #250   Spotlight this post!
Unread 18-03-2011, 21:57
President, VEX Robotics, Inc.
Re: Team Update #18
In my opinion, this is illegal per the rules mentioned above. The hostbot is providing a track that is pushing the minibot up vertically.
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
  #251   Spotlight this post!
Unread 18-03-2011, 22:04
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Re: Team Update #18
West Michigan from what I know found no problem with Team Update 18. From what I remember all minibots that went up scored.
  #252   Spotlight this post!
Unread 18-03-2011, 22:33
Kpchem Kpchem is online now
FTA, CSA, and all things technical
AKA: Kevin Emery
Kpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to behold
Re: Team Update #18
Update from Seattle Cascade:
Today there were no false positives in 64 matches on the Seattle Cascade field. If I remember correctly, there were two instances where a minibot successfully reached the top of the tower, but did not trigger the sensors. In both instances, the referees followed the latest Team Update and did not score it. Both of those minibots scored at other times throughout the regional.
FRC 360: 2008-2011
Full-time Volunteer: 2012 - forever
  #253   Spotlight this post!
Unread 18-03-2011, 22:48
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Re: Team Update #18
But the power is coming from the minibot. I therefore believe that it is legal. This would be an interesting topic in the "You make the call" section.
  #254   Spotlight this post!
Chris is me's Avatar
AKA: Pinecone
Re: Team Update #18
I've never thought of it that way, but I can't argue with that...
Sucks to be 190 and 233 I guess.
  #255   Spotlight this post!
Unread 18-03-2011, 22:53
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Re: Team Update #18
Be careful to paint both teams with the same brush stroke. Mark made a specific description of 190's deployment which made Paul think it's illegal, namely the creation of potential energy by the downward movement along the track. From my understanding, Pink's ramp only goes upward, meaning the track (and thus the hostbot) would not be contributing any energy.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
