| Thread Tools |
Rating:
Display Modes |
#241
Re: Team Update #18
Actually, that's quite good. You're right: any bot with the potential of winning the match (being the first to the top) will have enough velocity to trigger the pole. A lighter robot, unless it had an illegal battery or power source, would not have the velocity to create enough force, and the larger robot would being expending force on getting up the pole, therefore sacrificing velocity.
#242
Re: Team Update #18
But how much did your minibot weigh during this test, which found this diameter to be optimal? |
#243
Re: Team Update #18
Not sure if someone has updated everyone, but we have not had any issues at West Michigan so far
#244
Re: Team Update #18
Peachtree update:
No false positives, no false negatives (that I witnessed). Every minibot that made it to the top of the tower triggered the tower. It looks like, for peachtree at least, all this worry was for naught. ![]() |
#245
Re: Team Update #18
That's wonderful!
#246
Re: Team Update #18
Re: Team Update #18
I don't think so. When it grabs the pole it will slow down and then accelerate again. It can't climb faster than it can free spin or even travel horizontally, not on Earth anyways.
#248
Re: Team Update #18
I've seen a couple of teams (190 at WPI) with a clever deployment design that uses the same sized pipe curved to mate to the tower.
The minibot starts out accelerating downward off the hostbot (gravity a plus), then follows the curving pipe to start up the tower at full speed. |
#249
Re: Team Update #18
<G19> means that HOSTBOTS are not allowed to launch the MINIBOT up the pole at the TARGET, or otherwise contribute to the vertical movement of the MINIBOT. Energy for vertical movement may not be stored in the MINIBOT before DEPLOYMENT (except that which is contained within the battery and excluding incidental kinetic energy stored in the motors or wheels, but NOT, for example, in a flywheel). (My highlighting, not FIRST's) Since DEPLOYMENT starts when the miniboot crosses into the cylinder, it cannot have energy other than "incidental" kinetic energy in the wheels. Incidental horizontal running starts prior to crossing into deployment-i.e., the length of the minibot will probably be overlooked as incidental. Converting the horizontal energy produced by the minibot while over the cylinder is allowed: so the speed at the point of crossing the start line for a ramp can be higher than a minbot that uses an arm to place the minibot on the pole. I think a ramp bot can reach a higher top speed but the question is how much faster can other mechanisms get the bot to the start line as compared to the ramp bot. If the non-ramp bots do not start with a significant lead, the ramp bots can pass them (Assuming equal efficiency). Also of note: the ramp needs to be well below the start line such that none of the minibot is in contact with it when any of the minibot crosses the start line. My bet is that a ramp bot will record the fastest time. (We do not have a rampbot: at least not yet )Also of note: rampbots need to demonstrate that their hostbot does NOT provide horizontal momentum to the minibot: E.g., a host bot that suddenly decelerates as it is reaching the tower and is not completely motionless as it deploys the minibot COULD be imparting non incidental kinetic energy. Referees will need to watch out for that. |
#250
Re: Team Update #18
Re: Team Update #18
West Michigan from what I know found no problem with Team Update 18. From what I remember all minibots that went up scored.
#252
Re: Team Update #18
Update from Seattle Cascade:
Today there were no false positives in 64 matches on the Seattle Cascade field. If I remember correctly, there were two instances where a minibot successfully reached the top of the tower, but did not trigger the sensors. In both instances, the referees followed the latest Team Update and did not score it. Both of those minibots scored at other times throughout the regional. |
#253
Re: Team Update #18
But the power is coming from the minibot. I therefore believe that it is legal. This would be an interesting topic in the "You make the call" section.
#254
Re: Team Update #18
Sucks to be 190 and 233 I guess. |
#255
Re: Team Update #18
Be careful to paint both teams with the same brush stroke. Mark made a specific description of 190's deployment which made Paul think it's illegal, namely the creation of potential energy by the downward movement along the track. From my understanding, Pink's ramp only goes upward, meaning the track (and thus the hostbot) would not be contributing any energy. Last edited by Karthik : 18-03-2011 at 22:59. |
