Go to Post But, as a mentor I should caution you that FIRST is not about you its about the students. - SomeoneKnows [more]
Unread 18-03-2011, 21:40
siggy2xc siggy2xc is offline
AKA: Tyler Siegrist
FRC #1756 (Argos)
siggy2xc is an unknown quantity at this point
Perfect driving using encoders?
What would be the best way to make your robot drive perfectly straight using encoders while still being able to drive it with a joystick?
Unread 18-03-2011, 22:17
Jimmy the Kidd's Avatar
Jimmy the Kidd Jimmy the Kidd is offline
Programmer, Scouter, Tactician, etc
FRC #0364 (Team Fusion)
Team Role: Tactician
Jimmy the Kidd is an unknown quantity at this point
Re: Perfect driving using encoders?
By encoders, are you referring to encoders on, say, Supershifters? You could set a gain running on the encoder voltage, use the joystick value, and somehow compare the two, possibly using a coerce, to keep it within a certain range.
The GDC needs to write the rules once and let the game be what the game is going to be. There's little that's fun about being told exactly how to play with your toys. - Madison
Unread 19-03-2011, 01:13
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
You could interpret the joystick as a velocity command (rate).
If you are using one joystick (arcade) your code could look something like this:
(Sorry, I don't have labview on my computer)
double driveCmd = Joystick1.getY(); // Convert the Y axis value into a velocity relative to the robot's maximum speed
double turnCmd  = Joystick1.getX() * MaxTurnRate; //Convert the X axis value into a turning velocity relative to the robot's maximum rotation speed
double turnRate = (leftEncoder.getRate() - rightEncoder.getRate()) / robotWidth; // Based on Kinematics of a differential (tank) driven vehicle
double turn = P * (turnCmd - turnRate); //Proportional control; Expand to PID if needed
RobotDrive.arcadeDrive(driveCmd, turn);
The only change needed for driving it with 2 joysticks (tank drive) is:
double driveCmd = (Joystick1.getY() + Joystick2.getY()) / 2.0; // Average the 2 sticks to get an overall Speed for the robot to drive
double turnCmd  = ((Joystick1.getY() - Joystick2.getY()) / 2.0) * MaxTurnRate; // Convert the difference of the 2 sticks to get a turn velocity command
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
