Go to Post If you thought two alliances racing to tip the bridge in auto was exciting, wait until they play autonomous chicken on the center line. :D - Alpha Beta [more]
Unread 19-03-2011, 15:42
Ian McShane Ian McShane is offline
FRC #3585 (Rogue Robots)
Ian McShane will become famous soon enoughIan McShane will become famous soon enough
Can i program limit switch with nxt
if so how
in FIRST, it's process over product, and team over robot.
http://www.roguerobotsof4h.com/
Team 3585 Rogue Robots of 4-H
Unread 19-03-2011, 17:06
Electrical Engineer
Rookie Year: 1995
Re: Can i program limit switch with nxt
Originally Posted by Ian McShane View Post
if so how
Ian,
I am assuming that you are using Labview for NXT (since this is where you are posting). Try looking at the "Wait for Touch" sample program here and see if it helps.
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 22-03-2011, 17:29
can you send me a pic of what this would look like?
Unread 22-03-2011, 17:55
also can you tell me if the limit switch will act as a touch sensor in the nxt programming?
Unread 22-03-2011, 22:34
Mike linked to a page where you can download the actual vi. You can open it with LabVIEW and see for yourself how it works.
Unread 23-03-2011, 16:33
oh i missed that thanks.
Unread 23-03-2011, 16:42
i cant open it. it won't let me open it because it says it is from an older version of labview.
