Go to Post hmmm... big open space between arena and pits... thousands of poof balls...thousands of high school kids hopped up on sugar and robotics.... sounds a little dangerous. - Courtneyb1023 [more]
Unread 02-03-2011, 12:41
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Limit Switches on CAN freaks out
We are using CAN to control our Jaguars this year, but we get an error every once in a while when we boot up the robot.
If the limit switch is pressed when we boot up, every now and then (it appears to be random, we can't find a pattern) NetConsole throws a bunch of errors, called "Code: -44087 ERRROR Status == -44087(0xFFFF53C9) in SetTransaction() of CANJaguar at line 392" . When this occurs, we can't drive any motors, as the entire CANBus dies.
Like I said, it doesn't occur everytime the limit switch is depressed, but if that were to happen in a match, we'd be screwed.
If don't know if it makes a difference, but we have a total of 4 limit switches. Two are on a Grey Jaguar, and when those switches are depressed, we have never had a problem. The other 2 switches are hooked up to the same Black Jaguar, and that is when the error occurs.
Unread 02-03-2011, 12:44
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: Limit Switches on CAN freaks out
Interesting. We have the same problem -- and we're using limit switches on one of our Jaguars. However, we would only lose control of our motors for maybe a half second or second or so before it would come back. Out of curiosity, why do you blame the limit switches -- does it not have this problem without them?
Someone had mentioned on a different thread that this error is due to improper termination. But ours seems to be properly terminated.
Unread 02-03-2011, 13:59
AKA: Matt B
FRC #1771 (1771)
We have never encountered the problem when the limit switches weren't pressed.
And yes, we have a proper terminator on the final jag.
Unread 04-03-2011, 02:12
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
The labview explanation for that error is that the C RIO doesn't have the files it needs (either the FRCBlackJagBridge.out or the FRC2CAN.out.. or whatever their exact names are).
I know from experience that it does give that error when it doesn't have the files, but it seems to sometimes give the error if you do have the files.
Our team is using limit switches too. One of them is almost always pressed, and even when some are pressed it doesn't give the error.
I don't recall the problem ever happening on our competition robot, with the 2CAN. Maybe I'll try moving the starter of the bus to a different black jaguar, without limit switches.
Unread 04-03-2011, 13:35
AKA: Matt B
FRC #1771 (1771)
We formatted our cRIO using the BlackJagBridge option on the cRIO image updater.
Do we need to FTP the files in, like last year?
Unread 05-03-2011, 00:30
WizenedEE's Avatar
AKA: Adam
I think you do; there's no harm in updating your software.
Remember to change the .ini file also.
Unread 07-03-2011, 13:30
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
NO!
Please do not replace the files in your image. The files that now come in the image are far newer than any that are posted separately on the CAN Jaguar Project on FIRST Forge. Please note that those files are all marked as obsolete. The imaging tool takes care of everything you need.
The only exception is if there is a new release from CTRE for the 2CAN plugin, then you may need to update that. In that case, only replacing the file is needed. The imaging tool will still modify the ini file for you.
-Joe
Unread 08-03-2011, 19:28
AKA: Matt B
FRC #1771 (1771)
Okay, thanks. We won't change anything.
Just hope that the CAN doesn't freak out during a match, or else we will have to do a rapid switch to PWM cables...
Unread 08-03-2011, 19:34
Note that there is another thread discussing an issue that may be the same thing.
http://www.chiefdelphi.com/forums/sh....php?p=1036479
Can you give any additional information about your setup, such as what language you are using, if you ever see this part way through a match or only on start-up, what CAN interface driver are you using, and any other information you think might help?
Thanks,
-Joe
Unread 19-03-2011, 21:56
PranavSathy PranavSathy is offline
Team Captain
AKA: Pranav Sathyanarayanan
FRC #0263 (Sachem Aftershock)
PranavSathy is an unknown quantity at this point
Hey, we were having getTransation() and SetTransaction() issues during our regional, our simple fix was to add a Wait(.01) before the drive was called, that fixed our errors, we added this inside our drive forward loop for autonomous, so it doesnt affect our teleop, but it seems to work like a charm, try it out and see if it works. Good luck!
This is MADNESS!
NO...
THIS...
IS....
FIRST ROBOTICS!
Unread 20-03-2011, 20:55
AKA: Matt B
FRC #1771 (1771)
We experienced the scrolling CAN issue during one match at our regional.
Despite rebooting the cRIO 4 times, it didn't help it. After the 5th reboot we were able to drive, but there were only 4 seconds left in the match.
We decided to trash the limit switch.
