#19
Re: Partial Jag failure?
Texas Instruments, the designer of the part INA193, specifically calls it a 'current shunt monitor': http://focus.ti.com/lit/ds/symlink/ina193.pdf I specifically provided an official application note above in which those parts are used in a replacement function over a current sensing application...and in the last post of the series...openly noted that it could also be called a 'current sense monitor' or 'current sense amplifier'. In point of fact, other manufacturers do...indeed...use the alternative naming. For example: Here national semiconductor refers to the same basic circuit by the alternative name... http://www.national.com/analog/ampli...ent_sense_amps Here WikiPedia furthers calling this a current shunt: http://en.wikipedia.org/wiki/Shunt_%28electrical%29 "An ammeter shunt allows the measurement of current values too large to be directly measured by a particular ammeter. In this case the shunt, a manganin resistor of accurately known resistance, is placed in series with the load so that all of the current to be measured will flow through it. The voltage drop across the shunt is proportional to the current flowing through it and since its resistance is known, a millivoltmeter connected across the shunt can be scaled to directly display the current value." Wonderful world of engineering...same idea, different words...and we are all using the same language. Let's try it in Korean or Japanese. This is merely a matter of difference of terminology. This is why I posted that 3rd post. Further, you are correct...of course...it's not always the MOSFETs that go. However, it never hurts to ask because the MOSFETs have even more reasons they can go. Last edited by techhelpbb : 20-03-2011 at 12:57. |
