Go to Post Yes, I try to win matches, but you don't want to disrespect opponents......just get on their nerves an awful lot! :D - Josh Goodman [more]
Unread 20-03-2011, 14:01
Re: Weirdest problem in autonomous mode.
Yes, if you get the message it means your main drive motors were shut down by the system.
If it's causing you problems in autonomous, then the message will appear at the beginning or during autonomous.
Unread 20-03-2011, 14:32
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
I really don't get this new "safety" code. Meaning... I don't know how to use it.
Is it like the WDT, do we need to feed it? How often?
How do I bypass it (I trust the FCS to stop me)?
Not knowing how it makes my code SAFE means it probably isn't.
Is there a write up somewhere?
Phil.
Phil Malone
http://www.GEARSinc.org
Unread 20-03-2011, 15:05
Safety Config Tutorial.pdf
It's just like the Watchdog in concept, but now hidden within specific LabVIEW FRC palette vi's. I'm also not sure it enhances safety, since if you don't understand what it's doing, then it'll probably get bypassed in an equally unsafe manner.
It's only implemented in the drive base Open 2/4 Motor vi's and subsequent uses of Tank/Arcade/Holonomic/Motors drive tied to that motor reference will feed the timer. It is not implemented in individual motor opens, such as for arm control.
The safety timer defaults to .1 second. If a call isn't made to Tank/Arcade/Holonomic/Motors with the timeout period, then the associated PWM outputs are set to zero.
It is easy to disable.
Simply double-click on the Open 2/4 Motor vi's you use in Begin.vi and you'll see "enable" right in the middle of the associated block diagram.
Just set it to "disable" to turn it off.
The concept behind the Safety Vi's is that during debugging/breakpointing or due to overly slow to respond code, the motors automatically get shut down, to keep the robot from running rampant.
It has the unfortunate consequence of invalidating a (what I consider a more efficient) style of programming and clutters up teaching basic programming concepts.
Unread 20-03-2011, 21:11
beth_hadley beth_hadley is offline
FRC #0548
beth_hadley is an unknown quantity at this point
Our team experienced an extremely similar error, and we too isolated the issue to the safety update to the config timer within arcade drive Although we initially tried to circumvent the issue by disabling the timer in Begin, this did not fix our issues in Autonomous. Our ultimate solution was to rewrite the WPI Robot Drive libraries without the safety update.
Autonomous is fixed, and now operates fine the first time through after reboot as well as every subsequent time.
We still use watchdog, although our timeout is 1 second rather than the default of 0.5 seconds.
Obviously, we have had a considerable amount of issues with the safety features provided, and I too feel that by eliminating them we are making our code more vulnerable. Any suggestions?, or can we be confident that there will be no issues at competition?
Unread 21-03-2011, 07:36
Itamar's Avatar
Itamar Itamar is offline
FRC #1943 (NeatTeam) & FRC #4590 (GreenBlitz)
Itamar is an unknown quantity at this point
I still don't understand. Why would the Safety vi be tripped during autonoumos and no during teleop?
Further more, why when I used the regular Set Motor Value vi did the Safety vi stop?
Unread 21-03-2011, 09:14
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Itamar,
Can you post an image of your code?
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 21-03-2011, 22:16
The Safety feature, when enabled expects for the RobotDrive to be updated at least every 100ms. If it is not, say due to a breakpoint, a solenoid timer, an infinite loop in a subVI called from teleOp, then the Safety VI will set the motor speeds, on only the late motor speeds to 0. Unlike the WD, this will not shutdown the entire robot, only the outputs that aren't being updated by the code.
The typical way that this crops up in auto is for the auto code to set the motor speed once, then delay for some condition such as time. The general idea was to build an equivalent for the Delay and Feed which was in the WD palette last year. The block(s) for Update and Feed weren't complete in time, and weren't put into the palette. Even with them, more complex movements including other types of I/O is a bit difficult to write.
Greg McKaskle
Unread 22-03-2011, 09:23
PhilBot's Avatar
AKA: Phil Malone
Originally Posted by Mark McLeod View Post
Thanks for the link to the Safety Tutorial.
It was very helpfull.
Too bad that Safety Enable isn't brought out as a terminal in the Open2/4 Motor VI. I'd rather not edit the underlying library VI's. OK, I'm lying... I love editing the underlying VI's... but it gets me in trouble when updates ship
Phil.
Phil Malone
Unread 22-03-2011, 09:56
There is a safety config vi for robot drive that lets you enable/disable it.
