Go to Post It's OK to make some mistakes, as long as you learn from them. - Doug G [more]
Unread 20-03-2011, 13:23
chemipanda chemipanda is offline
Budha
FRC #0240 (TEMPEST)
chemipanda is an unknown quantity at this point
Minibot under 2 seconds
How would I go about creating a minibot under 2 seconds. I now that I would need to remove the gearboxes and use a magnet. But I am wondering how I could come up with a way to make the output shaft of the motor longer while making it legal?
Unread 20-03-2011, 14:28
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Minibot under 2 seconds
There are several posts addressing this issue, and your questions are answered there.
Unread 20-03-2011, 14:37
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
There is no "need" to remove the gearboxes or use magnets to make a sub 2 sec minibot.
Gearboxes that are modified to a 10.4 to 1 ratio, custom PVC pipe wheels, weight around 3lbs and rubber bands to provide the normal force for traction is how we made very consistent ~1.8 sec minibots that do reliably trigger.
We did try a couple of iterations of rod wheel minibots but they were no where near as consistent for us....yet.
