Re: Top 25 ETCs after Week 3
great points guys, I will work on changing it for an event by event basis, obvious need based on 67's second performance
ETC: 45.5 ERC: 32.5 EMC: 12.8 apparently you guys were a monster. Quote:
I'll be working on changing the algorithm to only take the latest event ETC rather than overall ETC. Last edited by mwtidd : 20-03-2011 at 16:16. |
Can you provide the algorithm to calculate it for a given team at a given regional? I realize that it would be too difficult to do for everyone at Peachtree since the data isn't on Twitter, but we'd love to calculate it for ourselves to see where we stand.
Thanks! |
but in case your feeling ambitious: As each match gets added to a DB, add the alliance points to a running sum for each team. Team's total average = teams total / num matches Then once all the matches have been added loop back through all the matches again, but this time calculate your portion of the contribution: so say for red1: red alliances average = ( red 1's avg + red2's avg + red 3s avg ) / 3 red 1's contribution = redScore * (red 1's avg / red alliances avg) then add up all of your contributions and divide by the number of matches. note I am working on a script to get the matches from the first site for events not tweeted... however for those events you will only see etc erc and emc can only be calculated with the twitter feed. |
Top ETCs using teams latest events:
![]() Last edited by mwtidd : 20-03-2011 at 18:07. |
wow didnt expect to see us all the way up to 7th. that feels pretty good
If anything its more of an achievement because you are grouped with some truly amazing teams. Tier 1: top 3 Tier 2: top 10 Tier 3: top 25 |
#7
Alright, I've spent some time trying to re-create your calculations using the data from Peachtree. However, I keep getting a different number for our team (2415) than you do.
Some sample data: In match 5, blue alliance scored 39 points and was composed of 2415, 1683, and 3694 2415's average alliance score: 77.1 1683's average alliance score: 26.2 3694's average alliance score: 7.1 The average score of the teams on the alliance = (77.1+26.2+7.1)/3 = 36.8 2415's contribution = 39*77.1/36.8 = 81.7 Is this correct? I ran this calculation for all of our matches and found us to have an average contribution of 119.2. This disagrees with your value of 38. Any idea what I'm doing wrong/differently? Also, how did you break up the Peachtree data for our robot into ERC and EMC? I'm just using the data set on the FIRST website which only contains total alliance scores. Thanks for putting all this together and answering questions! You have my interest piqued. |
#8
so (77.1+26.2+7.1) instead of (77.1+26.2+7.1)/3 *trying to run through it off the top of my head doesn't always work out ![]() I have also thought about generating highs and lows, by removing a teams highest and lowest matches, to give an ETC window rather than a set value. every match is tweeted to the FRCFMS twitter feed and it contains one extra piece of information the red and blue bonus, which is the points put up in the race. by knowing this I can use the same algorithm i use for etc, but use it on the bonus score and then the alliance score - the bonus score (robot score) Last edited by mwtidd : 20-03-2011 at 19:29. |
#9
Just a note: Team 2054 has been renamed "TECHVIKES", not big blue crew. This is the second year under this name.
#10
So where do the cheesy poofs or high rollers factor into all of this?
#12
My system work off the twitter feed, if your regional is 1 of the 4 that didn't post, I don't have numbers for you. I will try to support untweeted regionals but I won't be able to supply ERCs and EMCs |
#13
thanks for the update!!!!
#14
Mike could you do an OPR calculation on the Minibot data for comparison since you already have the bonus data from the twitter feed. I imagine it will skew toward the extremes, and work a little better at identifying the best minibot. |
#15
I'm working on an excel file to calculate ETC for a given regional, but my calculations are still a little different than those in this thread. I'll post a file later and maybe you guys can tell me what's different. |
