Go to Post Volunteers are in short supply and we always need more. - Koko Ed [more]
Unread 20-03-2011, 15:51
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: pic: One-day Minibot
Thanks for all the compliments. This was more an experimental project, to prove a point to myself, rather than anything else. The point I wanted to prove is that this is very easy and simple to make, and works well. You may or may not see this on 696's robot. In either case, it'll be at Long Beach if anyone wants a look. I'm also thinking, maybe I could come up with something simple to be able to add this onto any alliance partner robot that doesn't have a minibot. Not sure how that would work with inspection though.
I fully expect many winning teams to have something similar, but it will have been much refined beyond what this is currently. I don't plan to do any further work on this, however there is a lot of room for improvement. There's probably .2 to .3 pounds you could easily take out of it, and you could cleanup the wiring, and optimize the roller diameter.
Anyhow, let me answer a few questions.
Originally Posted by jgw View Post
Any details on the switch at the top?
It's made for a household lamp or light fixture, and was purchased from a local hardware store. It's a push-button on-off type.
Originally Posted by Chris is me View Post
I'm very surprised that this minibot took 1.6 seconds to go up. My guess says it should go up in about 1.2.
Yeah, it was a little slower than I expected too. My first try, on a dead battery, produced a little smoke from the motors. They still appear to work fine, however, they may work better if they had never smoked. Also, the acceleration is a lot slower than I would have imagined.
Originally Posted by PhilBot View Post
I see that you have a limit switch to turn the bot on when it contacts the pole. I was planning to turn it on as it left the robot, but yours is probably more universally interchangeable.
This is exactly the idea. There's some friction that results from it, but I'm satisfied with a sub -2-sec climb.
It may be worth it to spin up the robot before you touch the pole. Play around with it and find out
It probably would. However, I'd be somewhat worried about wear on the "tires." Anyhow, the present state is as far as I'm going with this design.
Originally Posted by jvriezen View Post
Putting the magnet between the rollers assures there is no way the magnet can touch the pole.
This was the idea. I'd estimate there is about .045" between the pole and the magnets the way I have them mounted.
Originally Posted by VKP View Post
What material did you use for the rollers? It looks like some sort of rubber. Did you take it off of the Tetrix wheels? Or is that electrical friction tape?
Black latex tubing.
Originally Posted by JB987 View Post
He said 1.6 seconds from the base. Maybe he is referring to time it takes from breaking the plane at start of deployment to the trigger? Anyways, this looks much like our new iteration. Wonder if he left the pinion on and used set screws not visible from the front view to hold or if this is a straight press to the motor shaft. Nice work.
It's 1.6 seconds from right next to the pole, right above the base. I did not account for deployment time.
Originally Posted by BIGWILLI2081 View Post
how did you connect the motor shafts to the bigger shaft?
There are no set screws. The pinion gear was removed from the motor, and the shaft was drilled and pressed directly on. Unfortunately, one thing I did not consider is there is no really good way to remove the shaft from the motor, if you ever have to. So, for spare motors, you'd want spare shafts already pressed on.
Originally Posted by TEE View Post
can't see the battery
It sits on the back side of the C-channel. There's a small piece of aluminum angle on the bottom of the C-channel that it sits on, and Velcro on the whole back of it holds it on. Zip ties would work too.
Originally Posted by Nikhil Bajaj View Post
Just a note: you are correct in stating that the magnets can potentially add to the damping in the system and slow the mini-bot down. However, this is not friction, unless you are rubbing the magnets or something else on the pole.
http://en.wikipedia.org/wiki/Eddy_currents
This is a very common high school physics class demonstration, taking a vertical aluminum tube and sliding a magnet down it towards the ground. It can take longer than one would expect.
The magnets provide approximately 6-6.5 pounds of force to the pole. It's more than enough to let it drive upside down on a horizontal pole. You could probably get away with using less magnet force, but I wanted to be absolutely certain it stuck. Not sure how much magnet damping force results from this setup, but I imagine it's not much.
One other interesting thing to note, is I mounted the magnets with aluminum screws. I'm not sure if this would provide more or less force to the pole, as compared to steel screws. Anyone care to answer that?
Unread 20-03-2011, 16:22
SGS's Avatar
SGS SGS is offline
AKA: Christine Gebara
FRC #3103 (Iron Plaid)
SGS is a glorious beacon of lightSGS is a glorious beacon of lightSGS is a glorious beacon of lightSGS is a glorious beacon of lightSGS is a glorious beacon of light
How did you get the gearboxes off the tetrix motors?
Unread 20-03-2011, 16:37
With a small Phillips screwdriver.
Unread 20-03-2011, 16:58
Chris is me's Avatar
AKA: Pinecone
You'll also want a nut buster for the pinion.
Unread 20-03-2011, 17:37
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
How is the plate for turn-on connected to that switch?
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 20-03-2011, 17:50
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Did the teams who you drew inspiration from have any issue with you posting this?
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 20-03-2011, 17:52
AdamHeard's Avatar
Lead Mentor
I would assume so.
Unread 20-03-2011, 17:57
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
I would assume so.
Why?
Richard Wallace
since 2003
Unread 20-03-2011, 18:02
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
Each of the teams listed has competed at least once already. Their minibot designs are "in the wild" (118's and 148's were featured in videos shortly after ship). I really don't see any reason why permission would need to be sought from any of these teams to post a picture of a minibot inspired by their designs.
Unread 20-03-2011, 18:06
Engineering Mentor
FRC #0254
"In the wild" is up for interpretation. I know at least two of the teams mentioned aren't thrilled with this unveiling.
-Travis Covington
Unread 20-03-2011, 18:16
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
I could tell that by you asking the question. I find it somewhat bizarre that these teams think that there was any way that this minibot design was going to stay "under wraps".
This is not the first, or even the second place I have seen this design, it is the third. I have a picture of 1625's minibot from Wisconsin and I saw 2415's in person at Peachtree this weekend. Both the picture and in person looks gave me sufficient information to build a similar minibot without much trouble.
Judging by the post by Chris is Me, this minibot design is circulating around New England as well.
The nature of the minibot task is such that by Champs many minibots will be very similar. Instead of spending time posting about people copying it, your time may be better spent optimizing both minibot and deployer to get every last tenth you can. I don't like it either, haven't since kickoff, but that's just the way it is.
Unread 20-03-2011, 18:19
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
xx
Unread 20-03-2011, 18:57
1708xMr.Roboto's Avatar
1708xMr.Roboto 1708xMr.Roboto is offline
Eddie
AKA: Eddie
FRC #1708 (AMPED Robotics)
Team Role: Driver
1708xMr.Roboto will become famous soon enough
Send a message via AIM to 1708xMr.Roboto Send a message via MSN to 1708xMr.Roboto
Gracious Professionalism, that is all.
Facebook 1 - Chief Delphi 19382193
Unread 20-03-2011, 19:06
AdamHeard's Avatar
Lead Mentor
Is it unGP for a team to be upset by someone else publicly posting their design?
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
1986 also used this same minibot design. They even posted some specs from it in another thread.
