Go to Post Well I guess that's better than some teams idea of team bonding which would be taping a wayward freshman to the wall with duct tape. - Koko Ed [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 12-11-2002, 22:25
Ian Mackenzie Ian Mackenzie is offline
FRC #3683
Ian Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond repute
EduRobotics problems
I just started trying out one of the EduRobotics kits out tonight, and it doesn't work. First, the 'Program/Tether' switch (used because the controller only has one serial port for both functions) came off, I assume during shipping. No matter what I do, the controller does not seem to get any signal from the Operator Interface (neither tether or radio seem to work). The PBASIC compiler can't detect it through the serial port either - not that it would have much mattered to start with, as the EDU default program downloaded from Innovation First doesn't compile (silly mistakes like having a variable in the serin command that had been commented out above, and then using a 'temp' variable that had not been declared). Is anybody else having these problems?
Ian Mackenzie
Unread 13-11-2002, 07:05
Electrical Engineer
Rookie Year: 1995
Ian,
I would most definitely call Innovation First at 903.454.1978 and get them involved... Most of us are just now receiving our kits and will likely not have any "constructive" comments for a while.
I.F. is your best choice... Let us know how you make out...
Mike
Mike Betts
As easy as 355/113...
Unread 13-11-2002, 14:14
Andrew Andrew is offline
Andrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to all
The first thing I did when I encountered this problem was to check the supplied batteries. They were very low, although the power light on the Edu-RC came on. When I charged the batteries and plugged back in, the Edu-RC front panel lights started blinking madly, just like they're supposed to. When I turned on the OI (using the wall transformer), it checked through its list of channels, found the Edu-RC and functioned normally.
I did not have to download code. I just hooked up the way the diagram that came with the kit indicated.
I then hooked up the system on the tether (don't plug in the OI to the transformer). Although the system did work, every time I activated a relay, the OI reset. Those little Ni-cads don't seem to have enough juice to drive both the RC, a motor, and the OI. Maybe if I charge for a while longer...
By the way, the OI that comes with the EDU-KIT is the same OI that we will have to use with our 2003 robot. Don't know if everyone knows that...
Andrew, Team 356
Unread 13-11-2002, 16:03
FRC #3683
Thanks a lot - I will charge the batteries tonight. I know you don't have to download the program; I really just wanted to check if the compiler could detect the controller.
Unread 13-11-2002, 18:01
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
PLEASE MAKE A NOTE OF THAT!
We received our EDUrobot today, and i was going through the parts, and i saw a little slip of paper. after reading it, having someone else double check it, and then reading it myself again (i'm so skeptical i don't even believe what i see for myself ) i quietly packed up the OI and OI Radio, and made sure to put it in the locked cabinet. no one, and i mean NO ONE, is touching those two items (i'm just going to use the 2002 OI to control the EDUrobot i think).
one other thing i noticed. only 3 LEDs for the 2003 OI, unless I just missed one in my excitment. if no one can confirm this by tomorrow i will, but it's something somone should check up on.
AIM --> Woloi
Email --> ian@woloschin.com
Unread 13-11-2002, 18:24
FRC #3683
Nope, there are definitely 4 LEDs (well, really 4 numbers x 7 LEDs each = 28, but you know what I mean).
Unread 13-11-2002, 21:47
Gui Cavalcanti's Avatar
Gui Cavalcanti Gui Cavalcanti is offline
Robogeek
Gui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to all
Send a message via AIM to Gui Cavalcanti
Does the OI look any different? If so, please post a picture or something so we can take a good long look.
Thanks!
Gui Cavalcanti
All-Purpose College Mentor with a Mechanical Specialty
Franklin W. Olin College of Engineering, Class of 2008
Unread 13-11-2002, 22:26
Suneet Suneet is offline
Physicist-In-Training
None #0599 (RoboDox)
Suneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to behold
Send a message via ICQ to Suneet Send a message via AIM to Suneet
We just got our kit today... that little motherboard is so cool! Well, if you received a controller with 4 numbers, I think mabey they're only giving those to teams with four digit numbers. Ours is a three digit.
Unread 13-11-2002, 23:21
College? What?
that would explain why i'm confused, cause i'm pretty sure ours was only 3 LEDs .
AIM --> Woloi
Unread 14-11-2002, 00:08
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
If you look at page 5 of the EduRobot Quick start guide (http://www.innovationfirst.com/FIRST...tart_Guide.pdf ),
you will se different instructions for 3 and 4-digit displays. I am assuming this means they only sent 4-digit displays to teams with numbers >1000.
Unread 15-11-2002, 14:00
AlbertW's Avatar
AlbertW AlbertW is offline
harker robotics :. 1072
AKA: Aonic
#1072 (Harker Robotics)
AlbertW is on a distinguished road
Send a message via AIM to AlbertW
our program/tether switch came off during shipping too. There's a little plastic tab it usually clips to that's broken off. We just hot-glued the switch back onto the contacts and it worked just fine. Try putting the switch back on, and holding it down and downloading the program (try the switch in both positions)
It should work
We were the first seeded first-year team at a first-year FIRST regional.
Unread 16-11-2002, 08:48
Ricky Q.'s Avatar Unsung FIRST Hero
Ricky Q. Ricky Q. is offline
yee haw!
FRC #0148 (Robowranglers)
Ricky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond repute
Send a message via AIM to Ricky Q.
Nope, we got ours thursday and we have a 4-digit display (#269), so I don't know what they are doing
Ricky Quinones
Director of Sales - VEX Robotics
Unread 16-11-2002, 10:26
College? What?
we have a 3 digit display (810). i haven't played with it yet, because i'm afraid i'll do something stupid and break it . i did compare it to the 2002 OI, and it looked exactly the same. then i packed it back up and put it away .
AIM --> Woloi
Unread 17-11-2002, 21:15
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Did you get any CH Flightsticks?
Originally posted by Ian W.
[Bi did compare it to the 2002 OI, and it looked exactly the same. then i packed it back up and put it away . [/b]
(We don't have our kit yet... Later this week, hopefully) Why did you put it away? If you don't wish it to run autonomously, how are you controlling the robot without the OI?
If you have to use the OI, did FIRST happen to mention their expectations about building a control panel board now? I'd think you almost HAVE to screw things onto at least a crude pine board plank to prevent component damage. Those connectors are FRAGILE, and don't take to cord tugging very well! The strain relief DOESN'T...
(I guess they can require you to build ANOTHER mounting board in January. It shouldn't take that long to do...)
- Keith
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
Unread 22-11-2002, 21:06
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I have a question. Does anyone have info on the battery charger that comes with it. I need to know if it is a peak charger or a timed charger. Thanks.
Do you all have problems with.... Munkaboo Website Design/Showcase 19 03-03-2003 19:51
Joystick problems archiver 2001 3 24-06-2002 02:40
Radio problems -- not archiver 2000 1 23-06-2002 22:23
What problems have you encountered using treads? M.I. Technical Discussion 8 15-01-2002 22:13
Speed Controller/PWM problems.... Clark Gilbert Technical Discussion 8 08-01-2002 00:14
