Go to Post And I think the poll needs another option: WILL be under weight ... eventually ... just get me a drill. :D - Franchesca [more]
Unread 20-02-2011, 14:06
Geek 2.0 Geek 2.0 is offline
FRC #0107
Geek 2.0 will become famous soon enough
Startup Twitch
After a robot reset, our robot doesn't respond for about 5 seconds after enabling, and then twitches (quite violently) and then responds to our control. We're using Java. Can anyone think of a reason for this twitchiness?
Unread 24-02-2011, 12:58
Frenchie461's Avatar
Frenchie461 Frenchie461 is offline
iScout
AKA: Brian, Frenchie, or that guy
Team Role: CAD
Frenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the rough
Re: Startup Twitch
it could twitch from all components powering up and testing, or it could be because of a bad CRiO.
"As a general rule, the most successful man in life is the man who has the best information." - Benjamin Disraeli (1804-81)
Unread 24-02-2011, 13:04
indubitably's Avatar
indubitably indubitably is offline
AKA: Ryan Guinn
FRC #2338 (Gear It Forward), FRC #1732 (Hilltoppers)
indubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond repute
Re: Startup Twitch
Check to make sure your automated processes are not initializing and that your variables are not being set to anything odd initially.
Also, if you are using PID, you may have to tweak your gains so that they do not need to work themselves out.
FRC 1732 (Hilltoppers): Mentor
FRC 2338 (Gear It Forward): Mentor/Alumnus
FRC 4096 (CTRL-Z): Mentor
Unread 24-02-2011, 13:24
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Startup Twitch
If you have an I term, you have to reset it continuously while disabled. Or else, when you enable it, it has to unwind the I term before (or while) you begin to use it.
Kettering Motorsports
Unread 24-02-2011, 14:25
Re: Startup Twitch
The five second delay might be a camera or gyro initialization. Make sure you aren't calling for something like that in your Teleop code.
Unread 20-03-2011, 19:13
FRC #0107
Re: Startup Twitch
Okay I think I finally found the solution. When the robot enables, it doesn't clear out the previous values from the registers of the Jaguars (via CAN). So, upon enabling the robot, the speed controllers start at the same values as the round before, and then stop when they receive a new value. That time between start and stop is the twitch.
Can anyone confirm or deny this?
Unread 21-03-2011, 10:49
MamaSpoldi's Avatar
MamaSpoldi MamaSpoldi is offline
Programming Mentor
AKA: Laura Spoldi
FRC #0230 (Gaelhawks)
MamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant future
Re: Startup Twitch
Well... I can confirm this is definitely true with PWMs with both Victors and Jaguars but not sure about CAN as we have never used it. I would suggest that you "turn off" everything when leaving both the teleop and autonomous routines in your code (eg. set drive motors to 0.0, and clear any internal states of your control loops, etc). This will ensure that you don't need to be worried when enabling your robot about what it might do. We have definitely experienced this with the gyro initialization as well... but that was more of an issue in the pre-cRIO years.
