Go to Post Congratulations! Welcome to the hardest fun you'll ever have. - Undertones [more]
Unread 20-03-2011, 16:45
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Big Minibots
Originally Posted by dodar View Post
Why is it that alot of teams are building these huge and complex minibots? I mean teams are building minibots that look like they are maxing out the size limits near 12"x12"x12". Why build a big one over a small one?
Potential reasons:
1. Because they don't have someone who understands Physics leading the design.
2. Because they don't read Chief Delphi
3. Because they are ignorant of the world around them.
4. Because they lack the resources, or design experience to build something custom
I don't mean this post to be harsh. I lot of teams have put a lot of work into some very successful larger minibots. But as a matter of engineering and physics principals, a small and light one is the only correct way to do it, if the goal is to get to the top the fastest.
Unread 20-03-2011, 17:00
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: Big Minibots
As a famous engineer likes to say, design is an iterative process. I've visited the pits of a few teams* that began by building larger, heavier minibots, and evolved their designs toward smaller, lighter minibots. The physics is the same, but the numbers (weight, friction, wheel diameter, gear ratio) are different. Lighter = faster, after you get the design optimized.
*One of those teams has a leader who is also a physicist, and a teacher. I am certain she did not do the design for them, but I am also certain she did not allow them to believe their first design was good enough. The advantage of understanding the physics behind an engineering problem lies in knowing how to predict the theoretical best-case result -- after you have that knowledge, iterate until your actual result is so close that further effort is better spent on something else.
Richard Wallace
since 2003
Unread 20-03-2011, 17:16
boomergeek's Avatar
boomergeek boomergeek is offline
AKA: Mr. D (Dick DiPasquale)
FRC #0241 (Pinkerton Robotics)
boomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant future
Re: Big Minibots
Consider two teams on a dysfunctional alliance: both race to the same pole at the same time from opposite directions...
One has a 15 lb maxi-minibot...
the other one has a 2 lb mini-minibot...
oooh, the horrible noise.., then...
the maxi-minibot slowly climbs the pole with what's left of the mini-minibot wrapped around the maxi-minibot's chrome hood ornament.
Aaahh, but it's the twisted wreckage of mini-minibot that flattens into the tower plate with no worries about not providing enough force for long enough.
But no points are awarded because the mini-minibot did not use power from its battery and motors to climb the pole.
Can a 15 pounder with a "cow catcher" intentionally scrap off little minibots that get stuck on the pole?
That might be fun to watch.
We design for being on a dysfunctional alliance: all the time.
Unread 20-03-2011, 17:48
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Re: Big Minibots
I think it just ends up what works for you and your materials. If you can only use the Textrix parts and you don't have access to custom parts, you probably will have a bigger and heavier minibot. Its not that you are ignorant or anything its just what works for you and what you have. If you have unlimited resources you probably will have a small light minibot.
Unread 20-03-2011, 17:51
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Big Minibots
If one of the resources is "engineering talent", then yeah, having more resources helps. But you don't need much as far as tools/equipment/money to build a nice one. 330s minibot is amazing.
Unread 20-03-2011, 19:10
Electrical Engineer
Rookie Year: 1995
Re: Big Minibots
Originally Posted by sanddrag View Post
Potential reasons:
I normally respect your opinion but let's look at engineering and physics for a minute...
How many of those "small and light" minibots are using limit switches rated for AC only? Answer: All of them.
From an engineering perspective, this is reckless and stupid. AC current switches through zero 120 times a second and the arc created when one tries to open a circuit is extinguished.
This does not happen for a DC current. It is much harder to switch... The arc tries to bridge the gap resulting in contact pitting and/or welding. This arcing becomes even larger when switching inductive loads (like DC motors).
To pick an example, the Honeywell microswitch in the KOP is rated for 11 amps AC only. An electrical engineer would never use it for DC currents except at milliamp (logic signal) levels. And in the extreme cases where expected lifetime is measured in thousands of cycles, never at all...
Now, you can specify DC rated microswitches but they ain't so micro...
So... We have teams who use NXT controllers and NXT touch sensors and they end up with large, non-competitive but better engineered minibots. And then we have poorly engineered but competitive minibots whose mentors have turned a blind eye to good engineering and are just hoping that they get though the season without failures setting in.
The correct way is not necessarily the competitive way...
Just who is ignorant of physics or of the world around them?
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 20-03-2011, 20:14
Re: Big Minibots
Regards,
Mike
All valid points. Perhaps I should have been more specific in specifying engineering for the task at hand which is getting up the pole in the least time, with a life cycle of only a few times.
I completely agree on the switches. It's bad practice to use a switch for something it isn't meant for. In this case, it does seem to work, for a little while anyhow.
Unread 20-03-2011, 20:15
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Re: Big Minibots
Potential reasons:
Wow,
I didn't realize that you could be wrong three times with three bullets. I don't mean this to be harsh, but here is where you are wrong.
1. my kids understand physics. Since that's what I teach, I make it my mission to sneak it in when I can.
2. I read CD as well as a few other members of the team. I'm not quite sure what was meant by this statement. We should all take the best ideas and use them as our own? Wouldn't that make this whole process so VERY boring? Yeah, I pointed out the "one day minibot" to my team today. They thought it was very cool but is beyond our ability to make (the most complex machining tool we have is a drill press). They want to focus on a consistent deployment system after watching 3 weeks of events. To sum up the mood of the team: getting a 4 sec minibot up the poll every match >> 2 sec minibot up the poll 80% of the time.
3. ignorant is such a "large" word to use. I'm not sure how to respond to that, so I won't.
Some teams want the students to learn something along the way (i'm not saying you don't Sand). FIRST gave them the problem. They are the ones who are deciding how they chose to solve the problem. I can point out the mistakes and help them along the way, but I refuse to do it for them.
I think it comes down to how you want to inspire your team. I have my way, other mentors have different ones. Who knows which is best. I don't. I don't think anyone truly can. What I can say is there isn't one correct way to do anything.
Unread 20-03-2011, 20:20
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Big Minibots
Since teams have been posting pics and vids of their robots and minibots something I have been noticing as been getting to me. Why is it that alot of teams are building these huge and complex minibots? I mean teams are building minibots that look like they are maxing out the size limits near 12"x12"x12". Why build a big one over a small one? Pros? Cons?
Because ours worked 100% of the time.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 20-03-2011, 20:24
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Re: Big Minibots
Regards,
Mike
This is FIRST. People shouldn't give a hoot about lifetime ratings in this case; the part needs to last a grand total of about 1-2 minutes max in competition. I'd take something even lighter than the KoP Honeywell switches if I could get my hands on them. It is better engineering to realize that the task at hand requires performance wayyyyyy over survivability.
Attending: MN Duluth Regional
Unread 20-03-2011, 20:26
wilsonmw04's Avatar
Coach
Re: Big Minibots
i'll remember to tell that to a team who's minibot burns out half way up the poll in elims.
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Big Minibots
Regards,
Mike
1) although it may be common for teams to use AC microswitches, not all teams do. A small minibot could be engineered very well.
2)Engineers solve problems to be effective and efficient. The problem at hand is triggering the target before the other minibots. If you are too busy trying to extend the lifespan of a $1.50 (more or less) switch at the cost of abandoning the overall goal, you are not engaging in good engineering practices either. If an NXT gets smashed you are out $150.00, for just 5% of that cost, you could replace a microswitch 5 times. In addition, the initial cost for a microswitch based system is about 0.6% of the initial cost of an nxt based system if you include the touch sensor and the motor controller. Thus, the most effective system in terms of how fast the goal is reached and cost is the small minibot. The big minibot just has too many disadvantages.
Unread 20-03-2011, 20:30
boomergeek's Avatar
Re: Big Minibots
Regards,
Mike
Destruction of material and risk taking IS part of good engineering, especially part of race engineering.
The competition is not about the team that builds the minibot with the least cost, most reliable parts that never degrade over the course of a season.
Teams spend many thousands of dollars per season and most of the parts depreciate in value very quickly most KOPs are replaced within a few years.
How much engineering maintenance does a NASCAR need compared to the family minivan?
Per mile, how much more often does a NASCAR fail as compared to a family minivan?
In reading the competition manual as a good engineer, are the requirements for the portion of the competition regarding the minibot more like NASCAR or like the family minivan?
Is it correct engineering to teach students to build a minivan for a NASCAR race?
There are plenty of relatively reliable 2.5-3 lb minibots.
If FIRST wanted the best teams to use the NXT and motor controllers, they should have make a challenge more like a use of a minivan- running all over town, picking up toddlers and groceries, making controlled stops, obeying all speed limits and signals, etc.
But then, who wants to go to a competition to watch that?
Probably not the stuff a Cirque du Soleil promoter could promote.
Has anyone had to replace a KOP limit switch from electrical overload in this challenge? What is the failure rate?
(Team 241 has used them without failure over 100 times.)
What is the perception of the other failure rates that the large minibot engineers have actual data to back up their concern?
Unread 20-03-2011, 20:34
WPI Freshman
AKA: Alex
Re: Big Minibots
If it's burning out halfway up the pole, it's safe to say they didn't engineer the thing - they just built it and prayed it would work. Complete burnout's like that would occur because the motor is operating in a red zone on the power curve, something that could have easily been avoided had analysis been done on the machine.
Unread 20-03-2011, 20:48
wilsonmw04's Avatar
Coach
Re: Big Minibots
but wait, hold on a sec. I thought you said that speed was "wayyyyy" more important than survivability. So by your example,not sacrificing too survivability for speed is a good thing. Thanks for proving my point :-)
Be aware not everyone analyzes the game the same way. Don't be so bold as to say your analysis is better than someone Else's. We all come from different places and experiences. There needs to be more middle ground around here and not all this "i'm right and you're wrong" crap-o-la. It's getting a bit tiresome.
