Go to Post Hey that was easy, we settled the argument on CD in one post! :^) - KenWittlief [more]
Unread 15-11-2002, 18:25
RebAl's Avatar
RebAl RebAl is offline
ISee It When I Believe It
None #0329 (The R.A.I.D.)
RebAl will become famous soon enough
Send a message via ICQ to RebAl Send a message via AIM to RebAl
Post Comp Port Pinouts
Does anyone know what the pinouts for the comp port are (Besides 6, 8 and 12)
Unread 15-11-2002, 19:10
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
No. Do a search. This question has been asked many times, and every time the consensus is that nobody really knows.
Unread 17-11-2002, 22:49
There are 12V and GND connections and pins for disable RC outputs and channel select enable.
If you read the manual for the OI, you will find the connections for all but the 12V connection, which is used by the Johnson "Yellow Dongle" for the "disabled" LED. Since it is inactive when the power supply is not used, the light doesn't work then. You can power the OI through this pin.
Caution - pin 8 is the only pin that should be used for ground. Some printouts of the manual and the manual for the Dongle may say otherwise, but are in error.
Competition port cable Ken Leung Electrical 2 17-09-2003 08:12
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
Dashreader.dll: A Visual Basic .NET user control to read the dashboard port Ameya Programming 4 12-01-2003 23:40
Change to Initializing Inputs and Outputs Jferrante Programming 4 07-01-2003 11:36
Relay Outputs OddOne Technical Discussion 3 01-02-2002 19:52
