Go to Post New mentor joins one team and ends up impacting several in the same region. I like that. :) - Travis Hoffman [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 21-03-2011, 15:18
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Re: A different Serial CAN problem.
Originally Posted by jhersh View Post
Sounds like you had a short between the wiper and ground on your pot.
-Joe
Unlikely. It hapenned on both arm joints at the same time. I also measured the return wiper voltage and both changed when the joints moved.
The only thing these joints had in common (other than system power) was the CAN bus and the cRIO/code.
Phil.
I tell you, there is weird S**t going on with this system.
Phil Malone
http://www.GEARSinc.org
