Go to Post Wait...you're supposed to have a driver? I guess I should have read past the Autonomous section in the manual :D - ASD20 [more]
Unread 21-03-2011, 16:05
PaW's Avatar
PaW PaW is offline
AKA: Paul W
FRC #1899 (Saints Robotics)
PaW has a spectacular aura aboutPaW has a spectacular aura about
pic: FRC1899 Control Board
Unread 21-03-2011, 16:09
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: pic: FRC1899 Control Board
That's probably the coolest control system I've seen so far. Have you considered adding scale model driver stations and pegs?
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 21-03-2011, 16:19
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
We did a similar controller this year as well. Although, we only controlled one axis. We made a scale model of our robot's arm geometry. We found that because the rotational axis moved greater than 270 deg. normal potentiometers would not cover the entire range of travel. So, we replaced the standard potentiometers with continuous rotation pots.
Here is the "secret sauce" we used for scaling.
The robot controller supplies +5vdc to an analog input device. The Cypress board only provides +3.6vdc.
So we simple multiplied the sampled voltage from the Cypress by (5/3.6)=1.389.
Here is the logic:
At one end of travel, both pots will give you 0vdc. At the other end, one will give you 5vdc and the other 3.6vdc. Both travel the exact same distance, so scaling is linear, just multiply the lower value by the scaling factor and now they are identical throughout the range of travel.
Unread 21-03-2011, 16:34
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
Do you have video of this working? I'd love to see it!
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
Unread 21-03-2011, 17:27
spacepenguine spacepenguine is offline
AKA: Ian Hartwig
spacepenguine is an unknown quantity at this point
That's darn cool. And I thought we were clever with our pre-set positions...
2008-2011: #226 - The Hammerheads
Unread 21-03-2011, 18:18
PaW's Avatar
PaW PaW is offline
AKA: Paul W
I'll see if our media team has any footage from practice.
Unread 21-03-2011, 19:43
davidalln's Avatar
davidalln davidalln is offline
World's Worst Coder
AKA: David Allen
FRC #2415 (The Westminster Wiredcats)
davidalln is on a distinguished road
Send a message via AIM to davidalln
This is absolutely fantastic. Please post a video!
SANTOSH ANDREW DECKER RICK WYNNIE SEAN DEREK MATT
(alamo (semis), p'tree (CHAMPS!), nc (CHAMPS!), newton (quarters))
Best four years of my life. Thanks to everyone who made it happen.
Unread 21-03-2011, 20:10
mahumnut's Avatar
mahumnut mahumnut is offline
FRC #1418 (Vae Victus)
mahumnut is an unknown quantity at this point
absolutely amazing, nothin but props
Unread 22-03-2011, 00:13
davepowers's Avatar
davepowers davepowers is offline
Currently dreaming about robots
AKA: Danger Dave
FRC #1687 (Highlander Robotics)
davepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud of
Awesome control board, this is deffinatly inspirational! I'll be by your pit in St.Louis to check it out!
David Powers - Deans List Finalist - WPI 17' - Bleed True Clothing
1999-xxxx FRC228, GUS Robotics Inc.
2013-xxxx FRC1678, Highlander Robotics
Unread 22-03-2011, 00:15
penguinfrk's Avatar
penguinfrk penguinfrk is offline
AKA: Larry
penguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of light
In this picture, you can see some magnets embedded into the wooden panel. There are small pieces of metal on the scale model. The magnets are our version of the presets, having 6 magnet locations of the rack and one for transport mode. There is a physical barrier (small block of wood) that denotes the ground for tube pickup. There are youtube links in that picture thread.
Autonomous mode is on when the arm is "tucked away" under the robot, making all of the pots at their most extreme values.
We had an excellent freshman operating the arm. Best part of it? He understands every bit of programming behind it.
Larry
Saints Robotics 1899
High school intern at FIRSTWA
2011 Seattle Olympic Regional:
Website Excellence, FIRST Dean's List Award (for team captain Kevin Kimura), Tournament Winner (Thanks 3393 and 2990!), Chairman's Award Winner
