Go to Post As mentors we need to be good role models for students. Because like it or not, we will be role models. - mathking [more]
Unread 21-03-2011, 17:23
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Re: old robot kicker question
well, the problem is that in the loop is a flat sequence, with 2 frames. the first is timed for either 500, 625, or 750 ms (depends on kicking power), and the second is always 500ms
i thought that by itself would server as timing enough...
the power button has me confused... if this were digital electronics, all i would do is wire a nor gate to each reset of the flip-flop... but this isn't that
any ideas?
Unread 21-03-2011, 21:37
ratdude747's Avatar
AKA: Larry Bolan
I think i fixed it.
I found in the function block menu flip-flops. i used those to set the 3 button system. being an electronics guy, i knew how to wire them to do what i wanted.
I also moved the button/flip-flop section to the teleop.vi and clustered the kick boolean and the enum kick power to the periodic tasks.vi . i did it this way to make a future dashboard and/or autonomous project more modular.
i attached the teleop and periodic halves of the kick code. (well, screenshots)
edit- (not in pictures) i changed the cluster wire to a global variable. that way I can add it to my custom dashboard (I did, thanks to a tut. video), and if i want to do an autonomous demo, I can use the kicker without creating a conflict.
ID:	10457  Click image for larger version
