Go to Post Scouting wins championships folks...not draft orders. - Andy Grady [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 22-03-2011, 02:13
delt13 delt13 is offline
delt13 is an unknown quantity at this point
Exclamation Mobile Robot with labview
Hi Guys, I have access to labview 2009. I want to program a pioneer mobile robot p3dx with labview. I am new to robotics and I can find any sources online that can help me get started. I was wondering if any of you members can give some guidance on how to get started. I would really appreciate your help.
Thanks
Unread 22-03-2011, 10:33
jhellr13 jhellr13 is offline
FRC #4272
jhellr13 is an unknown quantity at this point
Re: Mobile Robot with labview
Try this link. http://team358.org/files/programming...2009-/LabVIEW/
It has a lot of pictures of basic labview code that could help you start
Unread 23-03-2011, 10:15
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
The PD3X comes with the ARIA software interface library, you will most likely interface with the PD3X through that library. Depending upon its API, you may find that writing an interface DLL (in Microsoft Visual C++ or something similar) might be best, to simplify your interface calls from the LabVIEW DLL node (which is almost exclusively how you're going to talk to the core system). Fortunately almost every "accessory" communicates via TCP/IP, so that communications can be done natively within LabVIEW with relative ease.
Good luck.
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
