Go to Post The next hint will be game hint #3. Everyone will go crazy trying to figure out which of the fake hints was hint #2. - Joe Ross [more]
Unread 22-03-2011, 07:21
Pi Fighter's Avatar
Pi Fighter Pi Fighter is offline
Insert Monty Python Reference Here
AKA: Trevor
FRC #1718 (Fighting Pi)
Pi Fighter has a spectacular aura aboutPi Fighter has a spectacular aura about
Re: Storing the program on the robot semi-permanently
If you're using LabVIEW, you deploy from the robot project. From the project explorer window, at the bottom of the tree, there should be a deployment tab. Open that tab, and there should be an icon labeled 'FRC Boot-Up Deployment'. Right click this and select 'Build'. Once it's finished building, right click and select 'Run as Startup'. The program should run every time the robot turns on. You need to be tethered to a programming computer, though. I hope this helps.
