Go to Post The term defensive robot and mechanum wheels do not belong in the same sentence together. - Koko Ed [more]
Unread 22-03-2011, 01:55
Deeper>Darkness Deeper>Darkness is offline
FRC #1378
Deeper>Darkness is an unknown quantity at this point
Storing the program on the robot semi-permanently
We've been looking for a way to download our program permanently on the robot without having to download it every single time. Our communication system is just the regular wireless system. Any help is much appreciated!
Unread 22-03-2011, 01:58
NickE's Avatar
NickE NickE is offline
_
Re: Storing the program on the robot semi-permanently
If you're using C++, in Wind River, just go to the FIRST menu at the top and click Deploy. You'll need to go into the Wind River settings to set your team number.
Unread 22-03-2011, 07:10
Chexposito's Avatar
Chexposito Chexposito is offline
AKA: Expo
FRC #1730
Chexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of light
i can't remember how but with labview there is a way to download it permanently... but if you have windriver, this is how you put code on the robot like NickE said.
Unread 22-03-2011, 07:21
Pi Fighter's Avatar
Pi Fighter Pi Fighter is offline
Insert Monty Python Reference Here
AKA: Trevor
FRC #1718 (Fighting Pi)
Pi Fighter has a spectacular aura aboutPi Fighter has a spectacular aura about
If you're using LabVIEW, you deploy from the robot project. From the project explorer window, at the bottom of the tree, there should be a deployment tab. Open that tab, and there should be an icon labeled 'FRC Boot-Up Deployment'. Right click this and select 'Build'. Once it's finished building, right click and select 'Run as Startup'. The program should run every time the robot turns on. You need to be tethered to a programming computer, though. I hope this helps.
Unread 22-03-2011, 07:35
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
You can do it over wireless.
